Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Product variations fields
- This topic has 0 replies, 1 voice, and was last updated 5 years, 5 months ago by
MJin.
- June 10, 2020 at 10:40 am #140142
MJin
Vendors need to be able to enter the UPC (GTIN) barcode on a single product and variation products. Currently, I have added a “Product GTIN (EAN, UPC, ISBN) for WooCommerce” plugin which allows me to import/export products in CSV file and able to input UPC barcode with the header “UPC” in CSV file. It also allows me to create a variation and enter the UPC barcode for each of the variations (not just a parent SKU). I know there is a ‘Product Custom Field’ option in WCFM but it only adds the custom field for the single product and/or Parent SKU, not variation SKUs.
Requests:
1. To be able to add a Product Custom Field on a variation level (not just a single/parent product) and be able to edit the custom field from the variations edit just like SKU.
2. To be able to import/export the Product Custom Fields via CSV file header such as UPC, Brand, Store.Thank you.
