Diwali
01Day 17Hr 48Min 15Sec
Diwali
Products appear twice
Viewing 3 reply threads
    • #55152
      Aleix Aguilera
      Good Morning,
      On the vendor page the products appear twice. The second one under the footer:
      https://www.coolturemag.com/store/aguilera/
      Is there any way to remove it?
    • #55153
      Are you using Elementor for creating WC Shop page template?
    • #55318
      Aleix
      Yes I do!
    • #55528
      OK, then please add this code to your child theme’s functions.php –
      add_filter( 'pre_get_posts', function( $query, $that = null) {
      	global $wp_query, $post;
      	$wcfm_store_url = get_option( 'wcfm_store_url', 'store' );
      	$store_name = urldecode( get_query_var( $wcfm_store_url ) );
      	if ( !is_admin() && $query->is_main_query() && !empty( $store_name ) ) {
      		$query->is_archive    = false;
      		$query->is_post_type_archive    = false;
      	return $query;
      }, 50, 2 );
  • The topic ‘Products appear twice’ is closed to new replies.
