Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Vendors › Products Export not working for vendors
- This topic has 17 replies, 2 voices, and was last updated 7 years, 7 months ago by
- August 22, 2018 at 10:44 pm #29259
hkgemnet
ParticipantWhen i log in as vendor then i cant export products from front end.
While admin can easily export csv of products.I guess this one due to user role capabilities.
Tried but couldnt found which capabilities are missing.
- August 23, 2018 at 12:28 pm #29344
You are right, vendor users have to be a special capability “export”
- August 23, 2018 at 1:48 pm #29362
hkgemnet
ParticipantVendor already has export capability.
But export not working for my vendors. - August 24, 2018 at 5:08 pm #29552
It’s WC capability issue, we already found this issue.
We will resolve this in WCFM next update.
- August 24, 2018 at 6:24 pm #29589
hkgemnet
ParticipantLet me know please when updated version is released.
- August 24, 2018 at 6:52 pm #29602
Next update will be there early next week.
- August 27, 2018 at 6:08 pm #29874
hkgemnet
ParticipantUpdated but no luck.
Unable to export using vendor account. - August 28, 2018 at 3:34 am #29899
Hope you are not disable anything from WC Vendors capability settings!
Between, go to WCFM Capability and press “Save”, it will refresh vendors’ capabilities.
Now take a look.Thank You
- August 28, 2018 at 6:30 pm #29997
hkgemnet
ParticipantThis reply has been marked as private. - August 29, 2018 at 9:10 pm #30154
I think this issue is because of something else.
1. WC Vendors / WC Vendors Pro has a setting – whether you want to restrict vendor’s from accessing wp-admin area? (https://ibb.co/dxMx09)
2. Possible you have enabled that, just set that OFF. I mean allow vendor’s to access wp-admin area from WC Vendors setting panel
3. Set “Backend Access” OFF from WCFM capability.Now check.
- August 30, 2018 at 6:05 pm #30243
hkgemnet
ParticipantThis reply has been marked as private. - August 31, 2018 at 4:47 pm #30353
Thanks for the all details.
I am checking all of your issues.
- September 2, 2018 at 6:05 pm #30534
hkgemnet
ParticipantLet me know when you have update.
- September 3, 2018 at 5:54 am #30598
Export issue has been resolved.
This was because of this plugin – “Indeed Ultimate Membership Pro”
- September 3, 2018 at 5:18 pm #30691
hkgemnet
ParticipantGreat CHEERS!!
So, did you make any changes on any plugin source code?
If yes then cant I update these plugins anymore?Just for clarification.
Appreciate your support.
Thanks - September 3, 2018 at 6:42 pm #30704
No no, I didn’t edited any code files.
Just changed a settings for that plugin, which blocked vendors from accessing wp-admin -> import/export
- September 3, 2018 at 7:34 pm #30705
hkgemnet
ParticipantGreat.
Cheers. - September 3, 2018 at 7:40 pm #30706
MemberYou are welcome 🙂
- The topic ‘Products Export not working for vendors’ is closed to new replies.
