Diwali
04Day 04Hr 30Min 08Sec
Diwali
Products import
Viewing 5 reply threads
    • #105313
      jp2019
      Hi
      I can’t import product tables in the csv format, they only appear on the media page as a file that doesn’t move the products of the store.
    • #105662
      What happening if you are trying to import this from WCFM Product Importer? https://ibb.co/7ySyp1V
      Import same CSV from WooCommerce default importer and check whether it’s working or not!
      Also be sure your CSV match with WooCommerce import CSV format! https://docs.woocommerce.com/document/product-csv-importer-exporter/
    • #105993
      jp2019
      I’m trying with woocommerce default products and it is’t working and I can import with the normal importer. Only not working into WCFM.
      What could that problem be due to?
    • #106438
      What is your WCFM Ultimate plugin’s version?
      Are you getting any error during import form WCFM product importer?
    • #106479
      jp2019
      Yes, I can only import to Woocommerce and I can’t import to WCFM Marketplace. The imported products don’t appear in the WCFM menu and the store can’t see them, even if they appear in the media files.
    • #107446
      Keymaster
      Please clarify, are you getting any error during import when using WCFM product importer? Or it’s showing success message? Are those products, added via WCFM importer, can be seen from WordPress backend?
      To debug this issue, you can share a temporary access details. Don’t forget to mark it as Private.
  • The topic ‘Products import’ is closed to new replies.
