Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM › Put Advanced Custom Fields above short description? Also a bug for taxonomy
- This topic has 1 reply, 2 voices, and was last updated 5 years, 10 months ago by
- September 28, 2019 at 1:48 pm #84240
Luke Lee
ParticipantHi, I have post few days ago and I got no reply…
I’m an WCFM ultimate user, please help.
1.
In the product edit page (front-end):
Currently seeking for a solution for changing the ACF fields’ position to under or above the short description
ACF fields or your custom fields are currently displaying under the tabs, which is not user friendly at all.2.
Also, I have encountered a bug, I’m using CPT UI plugin: https://cn.wordpress.org/plugins/custom-post-type-ui/
to create my custom taxonomy for product post types. It’s showing on the front-end product editor perfectly.However, the bug I found out was that when I uncheck my taxonomy (So didn’t check anything under this custom taxonomy), and submit, the value previous value will stay there.
The only way to over-write the previous value was to select another value, and uncheck the previous value.
Please check this video to see what I’m talking about: https://youtu.be/mrfctASKqGQPlease, been waiting for any kind of supports for a while, hopefully this time works…
- September 30, 2019 at 11:53 am #84482
ACF fields or your custom fields are currently displaying under the tabs, which is not user friendly at all.– This is not supported right now.
ACF or any custom field block always added as a tab under product manager.
– We will take care of this in next update.
- The topic ‘Put Advanced Custom Fields above short description? Also a bug for taxonomy’ is closed to new replies.
