Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Question about your add-on 'WCFM – PRODUCTS FOR LISTINGS INTEGRATION'
- This topic has 11 replies, 3 voices, and was last updated 7 years, 5 months ago by
- February 15, 2018 at 12:33 am #19123
Gaz Anson
GuestHi there,
I used Listable as my boat rental marketplace theme. My boat listing form is available to vendors via a navigation button called “Add Listing” at the top of the front page. If I purchase your WC Ultimate package, will your add-on called ‘WCFM – PRODUCTS FOR LISTINGS INTEGRATION’ work with that listing form? In other words, will my (job manager) listing form automatically include the option to add a product (booking) if I use your add-on? Or will it only appear in the listing when vendors create a listing in your dashboard view?
Gary
- February 15, 2018 at 6:31 am #19136
Well, first I want to know you that WCFM has no “Add Listing” form under it’s dashboard, it uses default “Add Listings” page.
For associating products with listing “Products for WP Job Manager” is essential, hope you already have that.
Now as you see in our documentation (https://wclovers.com/knowledgebase/wcfm-product-listings/) using WCFM Ultimate it’s possible to create a product instantly at the time of creating a listing, and off course it’s default add listings page, it’s not under WCFM Dashboard.
Is this clear to you, if you still have any confusion regarding this please know me.
Shhiv - February 15, 2018 at 12:31 pm #19163
gaz
ParticipantHi Shhiv,
Thanks for the reply. That’s all clear. 🙂
One question though: I have configured everything correctly (I believe) and DO have all the necessary plugins (am using WC Vendors plugins by the way, not Dokan), BUT … my “Add Listings” page does NOT display the option to add/manage a product like the demo (just shows the normal fields). Any tips where I might have gone wrong? Or options I might need to uncheck or check? Or where I need to look to troubleshoot this?
Many thanks for any suggestions.
Gary.
- February 15, 2018 at 12:35 pm #19164
That’s great and pleasure to know that things are working perfectly as per your wish.
For listing products I think you probably missed “Products for WP Job Manager” (https://astoundify.com/products/wp-job-manager-products/) add-on, it’s essential.
- February 15, 2018 at 9:29 pm #19181
gaz
ParticipantHi there,
No — I didn’t forget ’Products for WP Job Manager’. I have everything in place, hence my question. Can you help troubleshoot please?
Gary
- February 15, 2018 at 10:57 pm #19182
gaz
ParticipantThis reply has been marked as private. - February 16, 2018 at 5:13 am #19198
I think there has some conflict with some other plugin.
Are you comfortable to allow me to debug this on your site?
If so, then please share your site details here – https://wclovers.com/contact-us/
- February 17, 2018 at 8:55 am #19223
gaz
ParticipantThis reply has been marked as private. - February 17, 2018 at 12:54 pm #19232
Simha
Actually, in add Listings page add product page opens under pop-up so no really link required.
I have checked and it works perfectly in your site, please try yourself once.
For reference you may check this video once – https://youtu.be/ir6H0pLo9uw
Please know me if we can help you some other way.
- February 18, 2018 at 2:52 am #19234
gaz
ParticipantHi Simha,
No — I’m not talking about that view. I mean when Vendors log in through the front end of the website (info.kayakable.co) and fill out the ‘Add Listings’ page — see attached screenshot.
The ‘Create New Product” link goes to: “https://info.kayakable.co/add-listing/#”) but it should go to: https://info.kayakable.co/wcfm/wcfm-products-manage/
Can you go back and check this please?
You must be logged in to view attached files. - February 18, 2018 at 9:29 am #19239
MemberAhhh … that’s great to know that you finally got around this and it’s working for you.
Please know me if your require any further help form our end.
- The topic ‘Question about your add-on 'WCFM – PRODUCTS FOR LISTINGS INTEGRATION'’ is closed to new replies.
