Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Questions about invoices and adding products with WCMF ultimate
- This topic has 1 reply, 2 voices, and was last updated 7 years, 9 months ago by
- February 8, 2019 at 5:43 pm #47299
Mailant
GuestHi
I’m setting up a multilingual marketplace using WC Marketplace and WPML. I’m considering WCFM as Frontend Manager for the vendors.
I got a few questions for the use case “vendor adds products” with WCFM Ultimate:
– I understand the translation of the product descriptions can be made by the vendor. Right?
– Does the vendor get the automatic translation functionality from WPML as well?
– Can the vendor be forced to add a translation?
— If not, how will the product be added (only in 1 language, in both but without translation, etc.)?
– Can the vendor be forced to fill up predefined attributes depending on the chosen product category? (for example: Size and Material for T-Shirts, alcohol content and color for wine, etc.).
— If yes, how can I predefine the possibilities as a marketplace admin?
— If not, can you recommend a possibility to do this in WCFM using further plugins?Further, I have a couple of questions concerning the invoice:
– Can the marketplace admin configure the invoice?
— If yes, to what extent? (layout, content)
– Can the invoice be generated in different languages?
— If not, in which language would it be generated?Thanks in advance for you answer!
Best Regards,
Mailant - February 9, 2019 at 5:03 am #47338
Well, first you have to be sure, whether WC Marketplace supports WPML or not! As I know, it does not. It’s vendor structure break down with WPML.
So, please confirm this from their support!
- The topic ‘Questions about invoices and adding products with WCMF ultimate’ is closed to new replies.
