Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Refund possible bug ?
- This topic has 5 replies, 2 voices, and was last updated 6 years, 4 months ago by
- April 25, 2019 at 9:51 pm #59467
d-n-13
ParticipantHello wclovers,
refunding with admin side doesn’t update commission/sales numbers, but Reports and Withdraw gets updated fine.
check screenshot attached
after refund vendors reports gets updated and vendor cannot request withdraw, but the numbers needs to be fixed.
You must be logged in to view attached files. - April 29, 2019 at 6:07 am #59816
– Do you have refund this by directly change order status to “refunded”?
- April 29, 2019 at 9:29 am #59865
d-n-13
Participant– Do you have refund this by directly change order status to “refunded”?
Yes in wcfm, and in wp-admin i did do refund function normally.
Currently only vendors & customer can request refund. Admin does not have a way to refund properly for wcfm.
- May 1, 2019 at 12:43 pm #60192
– If admin refund line items from wp-admin -> orders it will update commission order accordingly.
- May 1, 2019 at 12:50 pm #60193
d-n-13
i did inwp-admin but wcfm orders labels did not update : https://wclovers.com/wp-content/uploads/2019/04/refund-bug.png
- May 1, 2019 at 4:33 pm #60251
MemberNo, it will not update anything in the list like WCFM refund status.
It will remove old vendor order and will create from scratch.
This is helpful for you to add/remove order item from wp-admin -> orders as well.
- The topic ‘Refund possible bug ?’ is closed to new replies.
