Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Refund section not visible in costumer area
- This topic has 17 replies, 3 voices, and was last updated 6 years, 9 months ago by
- October 12, 2018 at 7:27 am #33842
Alexandru
GuestHello,
Refund section for costumer is not visible – i use Shopkeeper – eCommerce WP Theme for WooCommerce.
The refund feature is enabled.How to fix it?
- October 12, 2018 at 8:13 am #33852
Kindly check this – https://ibb.co/fada3p
Be sure, you have enabled “Refund by Customer?” option.Between, what is order status?
- October 14, 2018 at 7:34 pm #33993
inspire
ParticipantThis reply has been marked as private. - October 15, 2018 at 7:08 am #34022
I will definitely check this.
But first please be sure those orders are not in these statuses – ‘failed’, ‘cancelled’, ‘refunded’, ‘pending’, ‘on-hold’
- October 15, 2018 at 12:44 pm #34041
inspire
ParticipantThis reply has been marked as private. - October 16, 2018 at 2:35 pm #34114
I will definitely take a look at it
But, access is not working for me. Can you please re-check!
- October 16, 2018 at 3:05 pm #34127
inspire
ParticipantThis reply has been marked as private. - October 17, 2018 at 1:47 pm #34183
Can you please give me that text customer details as well.
- October 17, 2018 at 1:56 pm #34187
inspire
ParticipantThis reply has been marked as private. - October 17, 2018 at 1:58 pm #34189
Sorry, my fault.
I am asking for “test customer” account where you have orders but “refund” button not visible.
- October 17, 2018 at 2:04 pm #34191
inspire
ParticipantThis reply has been marked as private. - October 17, 2018 at 3:34 pm #34203
What is password for this user?
- October 17, 2018 at 4:20 pm #34210
inspire
ParticipantTouD1100:(
- October 17, 2018 at 4:21 pm #34211
inspire
ParticipantThis reply has been marked as private. - October 18, 2018 at 4:56 pm #34325
MemberOK fine, i am checking.
- October 20, 2018 at 3:12 pm #34430
Sorry for the delayed update.
“JL Product Review” – this is the plugin which totally corrupt default WC Orders view.
With that plugin view – https://ibb.co/mGLh0f
Support and Refund both options are there as it should be.
If you want to use that plugin then please contact plugin’s author and ask them not to destroy WC default view.
- October 24, 2018 at 6:57 am #34704
inspire
Thanks for helping.
Last question on this topic – the Refund Section must be visible also for store vendor, am i right? Now is visible just for admin. How to make it visible fot store vendor, i guess is something from capabilities.
Same about Followers – how to hide this section for store vendors?Thanks!
Alexandru
- October 25, 2018 at 3:48 am #34874
Refund Section – it’s for approving any refund requests, now Admin is only allow to do so. Refund amount not processed automatically, it’s a manual process and admin only can do that. So this section is available only to Admin, it will not helpful to vendors. Vendor may off course check their refunds from Ledger Book.
Followers – do you want to disable this from module or just want to hide from vendor dashboard?
- The topic ‘Refund section not visible in costumer area’ is closed to new replies.
