Registration Store Locator
Viewing 4 reply threads
    • #134853
      luis.samouco
      Hello WC Lovers!
      When a vendor registers in my website here there are 2 fields where needs to add the address in the wizzard store set up.
      I am showing 2 pictures to explain the problem:
      1-There are to places where they can add their addressess! The top one seems to just be used to show the address on the Store page. If I just fill this one the Store will not appear in the Store List and there is no geolocation attached to the store.
      2-If I just use the second one the store will appear with geolocation on the Store List, but the address information will not display!
      Is there any code that I could add that would join this 2 address fields into one? (So that when a vendor adds their address it would go automatically to their store page information and the geolocation in Store List would work aswell)
      Thank you for your help!
    • #139007
      testpaid2322
      How to Set Default location or country(Malaysia) on Store List Search.for your reference please find attachment
    • #139013
      testfree123
    • #139057
      luis.samouco
      https://wclovers.com/knowledgebase/wcfm-mappress-google-map/
      See this link maybe it will help you
      and check this pictures might help you!
      Anyways don’t use this post to ask your questions.
      My question in this post is solved so DONT reply to this! Thank you
    • #139450
      testfree123
      in this attachment i want that the location is fix for everyuser.
      and second is i have created store for malaysia but when i search malasiya i find “No store found!”
  • The topic ‘Registration Store Locator’ is closed to new replies.
