Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Ask just Store logo , instead Store logo + Avatar
- This topic has 5 replies, 3 voices, and was last updated 6 years, 4 months ago by
- April 9, 2019 at 6:51 pm #57025
acauaferreira
ParticipantI would like to remove the option to add avator photo on profile manager.
And use just the Store Logo on Dashboard/Profile picture (Is there other parts that the avatar image appear?)Less is more.
Its a bit confused explain that a business vendor need to add personal image profile, and that their clients will not see their personal pics. - April 10, 2019 at 1:32 pm #57145
Well, vendor’s profile image is no where visible to customers.
It useful if you are setting up BuddyPress site, otherwise store logo is good enough.
- April 10, 2019 at 2:52 pm #57170
Jose
ParticipantHello acauaferreira!
If it helps you, I had the same problem, but I just changed the translation from Avatar to Store Logo.
Then, when the vendor sees this, simply place the logo of your store, it works perfectly in the ticket holder, because the customer sees the logo of the store and the name of the store.
Regards,
- April 11, 2019 at 4:51 pm #57303
MemberThanks @jose
Right, previously Inquiry and Support had Avatar visible. But now those are replace by Store Logo and Name.
- April 11, 2019 at 7:49 pm #57344
acauaferreira
ParticipantThis is what I question,i know that vendors profile image is invisible for customer.
IF the AVATAR appear just on dashboard and profile image, why is this important?
Why don’t use just Logo Store for everything to simplify for vendors?
Is it possible to where require avatar,the system show the logo store uploaded?**Jose**
If I translate Avatar to Logo Store, the vendor will ask me why they have to upload twice the logo store.Because in settings there is again the logo store upload. - April 12, 2019 at 9:16 pm #57508
– As I previously mentioned, it has many uses, but may be not require for your site.
Use cases –
1. Buddy Press
3. BB Press
2. Blog PostThank You
- The topic ‘Ask just Store logo , instead Store logo + Avatar’ is closed to new replies.
