Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Remove all Shipping State Blocks at once?
- This topic has 4 replies, 2 voices, and was last updated 6 years, 2 months ago by
Janneke.
- March 15, 2020 at 3:10 pm #111656
Janneke
In Vendor Shipping OPtions I don’t want options voor State rates but only Country.
I succesfully removed one Shipping State Block in CSS >
div#wcfmmp_shipping_rates_wcfmmp_shipping_state_rates_0 { display: none; }But as soon the vendor wants to add another country then a second Shipping State Block appears.
To remove that second Block I have to add in CSS >div#wcfmmp_shipping_rates_wcfmmp_shipping_state_rates_2 { display: none;Ans so on for every new added country so if vendor ships to 100 countries I have to put 100 codes in CSS(?)
Is here another way to hide or remove this Shipping State Blocks at once?
Please see attachment.
Thank you.
You must be logged in to view attached files. - March 18, 2020 at 12:18 pm #112125
Kindly use the following snippet –function remove_state_option($shipping_fields) { if(isset($shipping_fields['wcfmmp_shipping_rates']['options']['wcfmmp_shipping_state_rates'])) unset($shipping_fields['wcfmmp_shipping_rates']['options']['wcfmmp_shipping_state_rates']); return $shipping_fields; } add_filter( 'wcfmmp_settings_fields_shipping_rates_by_country', 'remove_state_option' );Add this code to your child theme’s functions.php file and let me know how this goes.
Thanks! - March 26, 2020 at 11:49 am #113248
Janneke
ParticipantSorry for my late reply.
This didn’t work. After uploading the functions.php file I could not login to wp-admin anymore.
After deleting the code and upload the file again it was fine. - March 29, 2020 at 11:45 am #113831
KeymasterHi Janneke,
It seems, there might be some copy pasting issue in your last attempt. Also I would suggest using https://wordpress.org/plugins/code-snippets/ plugin for code snippets.
If the problem persists, then I’ll require a temporary access of your site to further debug.
Thanks! - March 29, 2020 at 11:53 am #113833
Janneke
ParticipantThank you I will try the plugin.
Meanwhile would you please be so kind to answer to my other topic as well?
I really love Multivendor Marketplace but I need Mollie iDEAL to work in it.
It would be very sad that I can’t use WCFM because of that.Thank you very much.
- The topic ‘Remove all Shipping State Blocks at once?’ is closed to new replies.
