Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Delivery › Remove term "Delivery Boy"
- This topic has 2 replies, 2 voices, and was last updated 6 years ago by
sheridandoyle.
- February 25, 2020 at 1:34 pm #108695
sheridandoyle
ParticipantHi, I need to remove the term “delivery boy” from the entire website. I’ve removed it from the actual delivery tab but the term is still showing in the order tab. I would like to replace it with just “delivery” – is there a snippet that works across the entire site so that I can do this?
- February 25, 2020 at 4:30 pm #108712
Sarmistha Chakraborty
You can do that easily using string translation(no coding involved). You can use Loco translate plugin for this purpose. (How to use Loco translate – https://www.youtube.com/watch?v=ZUPhsoUm-QE)
Please select the plugin Loco Translate -> Plugins -> “WCFM – WooCommerce Frontend Manager – Delivery” for changing “delivery boy” text.Thanks.
- February 25, 2020 at 5:18 pm #108721
sheridandoyle
ParticipantGreat, thank you!
