Reorder Add Product Tabs
Viewing 1 reply thread
    • #118072
      ashley.younguk
      Hello
      I would like to reorder the tabs at the bottom of the add product page (Inventory, Shipping etc).
      How would I do this…
      I’ve installed ACF and create a few custom fields but they appear in the tab at the bottom and I Would like it to be at the top.
    • #121341
      Keymaster
      Try using the following snippet-
      function acf_fields_on_top() {
          global $WCFM, $WCFMu;
          if ( $wcfm_allow_acf_fields = apply_filters( 'wcfm_is_allow_acf_fields', true ) ) {
              if ( WCFMu_Dependencies::wcfm_acf_pro_active_check() ) {
                  // Advanced Custom Fields(ACF) Pro - Products Support - 3.3.7
                  remove_action( 'after_wcfm_products_manage_tabs_content', array( $WCFMu->wcfmu_integrations, 'wcfm_acf_pro_product_manage_fields' ), 60 );
                  add_action( 'after_wcfm_products_manage_general', array( $WCFMu->wcfmu_integrations, 'wcfm_acf_pro_product_manage_fields' ), 60 );
              } elseif ( WCFMu_Dependencies::wcfm_acf_active_check() ) {
                  // Advanced Custom Fields(ACF) - Products Support - 3.0.4
                  remove_action( 'after_wcfm_products_manage_tabs_content', array( $WCFMu->wcfmu_integrations, 'wcfm_acf_product_manage_fields' ), 60 );
                  add_action( 'after_wcfm_products_manage_general', array( $WCFMu->wcfmu_integrations, 'wcfm_acf_product_manage_fields' ), 60  );
      add_action( 'wcfm_init', 'acf_fields_on_top', 15 );
      Let me know how it goes.
  • The topic ‘Reorder Add Product Tabs’ is closed to new replies.
