02Day 12Hr 58Min 43Sec
Required fields in WCFM
Viewing 18 reply threads
    • #17612
      Brad Z
      Hello, I need to make the following fields required for vendors:
      Paypal email
      Custom Product Attribute – “Years of Experience”
      Please let me know if possible.
      Thank you,
      Brad
    • #17616
      HI Brad,
      It’s absolutely possible to achieve.
      Can you please show me screenshot of those fields so that I can help you accordingly!
      Simha
    • #17756
      sharkmediasport
      I’m also interested in having paypal email adress mandatory.
      Can you provide to code to do it ?
      JF
    • #17757
      Simha
      Yah sure, I will.
      Please know me just which multi-vendor plugin you are using in!
    • #17762
      sharkmediasport
      I’m using woocommerce product vendors.
      JF
    • #17771
      Here is your custom code for the purpose –
      function wcfm_wcpvendors_custom_settings_fields_billing( $billing_fields ) {
      	if( isset( $billing_fields['paypal'] ) ) {
      		$billing_fields['paypal']['custom_attributes'] = array( 'required' => 1 );
      	return $billing_fields;
      add_filter( 'wcfm_wcpvendors_settings_fields_billing', 'wcfm_wcpvendors_custom_settings_fields_billing', 50 );
      Just add this code in your site child theme’s functions.php
      Please know me is this works for you or not!
    • #17790
      sharkmediasport
      yes thank you very much, it is now required. Ultimately I would love to have it required on the vendor registration form but I don’t think I’m at right place to ask.
      Otherwise, your solution is good. Thanks !!
      JF
    • #17791
      Brad
    • #17792
      Brad
      Hi sorry, the custom code posted above did not work for me. I also cannot seem to paste a print screen into this chat so can I send it somewhere?
    • #17793
      This code is for Vendor’s Settings page Billing -> PayPal Email, and not for Registration form.
      Hope you are using WC Product Vendors default registration page?
      Let me try to find a solution for you.
      You have register and logged in to send attachment here. Or you may also directly send them in mail – wclovers.contact@gmail.com
    • #17857
      I just found this article – https://nicola.blog/2016/04/19/adding-custom-fields-vendor-registration-form/
      Hope this will helpful for you.
    • #17868
      sharkmediasport
      That’s very king of you, thanks for your time, I should be able to have something working from your link.
      JF
    • #17886
      Welcome 🙂
      Please know me if I can help you some other way.
      Simha
    • #17928
      bradziajor
      I do use WC Product Vendors and my request was for the Paypal field to be required on the WCFM screen, not registration. My other request was for a custom attribute to be made required. Screenshots attached for the custom attribute.
    • #17935
      I have already give you code for restrict PayPal field as required –
      It’s difficult set custom attribute as required as we have no clue how many custom attributes are there and which should be required!
      Can you please know us purpose of this “Years of experience”, actually I am just trying to understand if this possible to achieve some other way!?
    • #17951
      bradziajor
      Unfortunately, the code does not work as I stated before. I do have another field set as required, will that make a difference? Here is the custom code I already have:
      function wcfm_custom_product_manage_fields_advanced( $wcmp_advanced_fields ) {
      if( isset( $wcmp_advanced_fields[‘enable_reviews’] ) ) {
      $wcmp_advanced_fields[‘enable_reviews’][‘custom_attributes’] = array( ‘required’ => 1 );
      return $wcmp_advanced_fields;
      add_filter( ‘wcfm_product_manage_fields_advanced’, ‘wcfm_custom_product_manage_fields_advanced’, 50, 2 );
      Also, I only have one custom attribute and that will be the only one required. It is to tell customers how many years of experience the service provider has with the product they are selling.
    • #17954
      That’s really strange, why this code is not working for you.
      Just to mention, there is no connection between two codes.
      I just want to confirm one thing, you are using this plugin, right? https://woocommerce.com/products/product-vendors/
    • #17958
      bradziajor
      Yes, correct. I added this new code below the other code in Listify Child: Theme Functions (functions.php). I received an error that says “Unable to communicate back with site to check for fatal errors, so the PHP change was reverted. You will need to upload your PHP file change by some other means, such as by using SFTP.”
    • #17962
      There is no issue in this code, you may add this to your site. WP normally restrict PHP code update from WP editor.
      For demo I have just added this in our Product vendor demo site, kindly take a look. – http://wcpvendors.wcfmdemos.com/wcfm/
      if( isset( $billing_fields[‘paypal’] ) ) {
      $billing_fields[‘paypal’][‘custom_attributes’] = array( ‘required’ => 1 );
      add_filter( ‘wcfm_wcpvendors_settings_fields_billing’, ‘wcfm_wcpvendors_custom_settings_fields_billing’, 50 );
      Our team is looking for solution for “custom attributes”.
  • The topic ‘Required fields in WCFM’ is closed to new replies.
