Responsive Product Tabs
Viewing 1 reply thread
    • #53693
      Kevin
      In my theme, might be same for all, Woocommerce has it’s on section in customising theme. Appearance > Customisation > WooCommerce
      In the Single Product tab I can choose to have the Product Tab Layout as either vertical or horizontal.
      I prefer the look of vertical in desktop mode, but vertical doesn’t work great on mobiles, not very responsive.
      Do you know a fix for this?
      Happy if is custom css to swap mobile to hortizontal.
    • #53752
      Well, those are custom option form your theme, please contact theme author.
      WooCommerce default customize options are these – https://ibb.co/F5cs8MQ
  • The topic ‘Responsive Product Tabs’ is closed to new replies.
