Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Return Address
- This topic has 22 replies, 2 voices, and was last updated 6 years, 8 months ago by
nakedharmonix.
- September 5, 2018 at 7:08 am #30837
nakedharmonix
In our country’s law, EC vendors are obligated to inform their address to buyers.
How Can I setting “Return Address”.
I already set shop address, but it is not reflected im email and checkout page.
We using MCMp.
Regards,
TK - September 5, 2018 at 8:10 am #30854
As I know WCMp does not support “Return Address”.
WCFM Marketplace shows vendor’s customer support address at checkout and email as well – https://ibb.co/fAN02z
Please talk to WCMp support once.
- September 5, 2018 at 11:52 am #30888
nakedharmonix
In the previous version WCFM, this problem did not exist.
And,I forwarded your reply to WCMp.
WCMp supports “Return Address”.https://prnt.sc/kqqz33 https://prnt.sc/kqqzb5
When WCFM is enabled, the setting items required for “Return Address” of WCMp are hidden.
Off WCFM: https://prnt.sc/kqqyr 9
On WCFM: https://prnt.sc/kquxvlIs this a bug?
Or, the default specification of WCFM?I also ask this to WCMp about this problem.
- September 5, 2018 at 12:08 pm #30891
Don’t you have Custom Support setting under WCFM Vendor Setting panel? – https://ibb.co/dQWEvK
- September 10, 2018 at 11:41 pm #31279
nakedharmonix
Participant - September 11, 2018 at 12:05 pm #31335
For WC Marketplace this is only controlled by this setting option – https://ibb.co/mMFw5U
- September 11, 2018 at 12:45 pm #31345
nakedharmonix
I have already activated it on WCMp, but “customer support” is not displayed.
- September 11, 2018 at 3:01 pm #31350
MemberThat’s really strange!
Umm .. WCFM has no capability for this with WC Marketplace.
I have ever give you any custom code related to this?
Well, can you once go to WCFM Capability and save once.
- November 6, 2018 at 2:01 am #35843
nakedharmonix
This problem has not been solved yet.
I duplicated the site for resolution.
Could you log in as administrator and solve the problem? - November 6, 2018 at 2:02 am #35844
nakedharmonix
ParticipantThis reply has been marked as private. - November 6, 2018 at 6:30 am #35900
Kindly check now.
If not yet resolved then please share a demo vendor access with me.
- November 6, 2018 at 6:41 am #35906
nakedharmonix
ParticipantI have already invited you as an admin, but I will send you login information as a vendor.
Thank you.
- November 6, 2018 at 6:41 am #35907
nakedharmonix
ParticipantThis reply has been marked as private. - November 6, 2018 at 2:40 pm #35945
Memberhi,
Vendor password not working.
Between, do you checked after my message?
- November 9, 2018 at 1:04 am #36185
nakedharmonix
ParticipantThis reply has been marked as private. - November 11, 2018 at 7:07 am #36316
Now “test_admin” no more working for me!
- November 11, 2018 at 7:12 am #36319
nakedharmonix
ParticipantThis reply has been marked as private. - November 12, 2018 at 9:33 am #36452
Thanks for the details.
I have again resolved this, possibly your file system restore from backup*!
Custom Support tab available under vendor setting panel – https://ibb.co/jH8ckA
- November 12, 2018 at 9:47 am #36456
nakedharmonix
ParticipantThank you!
How did you fix it?
I want to know the concrete procedure.
I have to make it reflect on another site.
Regards, - November 12, 2018 at 10:05 am #36460
Kindly copy one file from here to your another site ->
wp-content/plugins/wc-frontend-manager/views/settings/wcfm-view-wcmarketplace-settings.php
Well, I have changed it’s line no – 696
- November 12, 2018 at 10:17 am #36464
nakedharmonix
Do I need to copy this file for each update? - November 12, 2018 at 10:19 am #36465
Not at all, it will be there in WCFM next update.
- November 12, 2018 at 11:58 am #36469
nakedharmonix
ParticipantOK,Thank you!
- The topic ‘Return Address’ is closed to new replies.
