Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Search by Product Location option not working
- This topic has 6 replies, 4 voices, and was last updated 5 years, 3 months ago by
Ekk Tiger.
- February 11, 2020 at 4:00 am #106589
NTexplore
ParticipantI tried using Geo my Wp and Map press to use filtering products by product location. I could not get that to work. I bought ultimate with the hope that this option would work. Can you please help.
- February 18, 2020 at 5:45 pm #107641
Well, WCFM Marketplace has this option inbuilt. Go to WCFM Admin Setting -> GEO Location -> Enable “Product List Radius Search”
Map and filter will visible under default WooCommerce product listing page like this – https://wcfmmp.wcfmdemos.com/
- April 14, 2020 at 7:26 pm #119081
karl ohin
I am trying to display all my products / some of my products on the map and not the vendor.
I want to offer a product page using the map so customers can find products by the map.
I have the GEO location working but it lists the vendor on the map.
The files attached show the products listed , this was a demo on sharetribe .
IT was a great feature that the products could be searched for on the map.
Is this possible with WCFM , i just vendor mapping .
You must be logged in to view attached files. - April 14, 2020 at 9:31 pm #119114
You can use GEO my WP or MapPress for this purpose.
If you go with GEO my WP, then you might find our documentation on this, useful https://wclovers.com/knowledgebase/wcfm-geo-wp/. After that you will require to add a search form, as GEO my WP doesn’t work with your default store search. Follow this tutorial to get the idea – http://docsdep.geomywp.com/create-a-search-form/
Thanks - April 15, 2020 at 2:33 pm #119319
karl ohin
ParticipantHi There
Thanks for this , i had the GEO my WP setup but was missing the display piece .
I got it working thats great. Can the map be put onto each category page – where i will display the products on the map for that category ?
thanks for your help
- April 15, 2020 at 7:32 pm #119398
KeymasterHello,
I think GEO my WP guys can better guide you on this one.
Thanks! - July 26, 2020 at 4:17 pm #155992
Ekk Tiger
ParticipantHello how are you.
Pls I need to slove this problem too. But the link to the guide is not working.
