Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Search for vendors on home screen. Results on different page
- This topic has 11 replies, 4 voices, and was last updated 5 years, 3 months ago by
Ramamurthy Krishnan.
- April 20, 2020 at 12:36 pm #120872
mauro.chuchuy
ParticipantHello WC Lovers!
I am hard at work on my new project. I am sorry to have to come to you with this but after days of research I can’t find a viable solution.
I will open a marketplace so users can shop from local grocery stores (within 1 to 2km distance) and have products delivered same day or pick up from store.
I’d like to have my homepage just show an address bar, so user can impute their delivery address and search for nearby shops.
I would like to have the results being displayed on a new page, call it “Vendor List page” and be able to filter categories there, choose a store and star shopping.I would also like to have the radius filter locked at 1km or 1.5km and BE hidden. Is it possible?
Attached Images of examples I am trying to imitate.
Thank you so much in advance for your help.
You must be logged in to view attached files. - April 24, 2020 at 3:37 am #122336
mauro.chuchuy
ParticipantHello all, I am wondering if my question is incorrectly posted in the forums or if its not a valid concern. Would like to know so I can move on and find a solution somewhere else. Please provide an answer. Thank you!
- April 24, 2020 at 8:35 am #122387
mauro.chuchuy
ParticipantHello again!
Regarding my question: “I would also like to have the radius filter locked at 1km or 1.5km and BE hidden. Is it possible?”
I found and answer in your forums that I could use to have the 1km option.
The question related to that is the following: Can I HIDE the radius filter in the [wcfm_stores] page but STILL have the address bar so customer can type address to find stores around?
- April 24, 2020 at 2:07 pm #122475
Ramamurthy Krishnan
Yes you can hide the radius filter option, just go to store-manager->Settings->GEO Location and you will find “Store List Radius Search” checkbox option, uncheck it and save , it will remove the radius filter from there.
- April 24, 2020 at 10:32 pm #122640
mauro.chuchuy
ParticipantHello, thank you for answering.
As I mentioned in my post, If I remove the radius I also loose the address bar as shown in the images attached.
I want to remove the radius and still have the address bar.
You must be logged in to view attached files. - April 24, 2020 at 10:33 pm #122642
mauro.chuchuy
ParticipantHere is the other image I was missing
You must be logged in to view attached files. - April 28, 2020 at 4:04 pm #124174
Ramamurthy Krishnan
Please add the below css code to your child theme’s style.css file.
.wcfm_radius_slidecontainer { display: none !important; }
- May 7, 2020 at 9:29 am #127854
mauro.chuchuy
ParticipantHi, that worked perfectly!
Is there a way I can place the search box (category, address bar and radius) on my homepage and when customers press “search” it will take them to the store locator?
- May 8, 2020 at 3:45 pm #128368
leab09
ParticipantI have the same request!
Results can be displayed on same page for us, doesn’t matter.
But t would be interesting to develop a way to ADD STORE LIST SEARCH BAR on LANDNG PAGE ?
Usually the search bar displays results of PRODUCTS while many of us need the search bar to look through SELLERS Categories and display SHOPS as a result.
- May 9, 2020 at 12:45 am #128572
mauro.chuchuy
ParticipantHi, my request is different though.
I was wondering if the WCFM_stores location bar could be placed on the homescreen, once the customer enters address and press search THEN take customer to WCFM_store LIST.
See example HERE https://prnt.sc/sddfct
- May 10, 2020 at 1:13 am #128950
iain.sandison
ParticipantIm after similar things hope you get a solution, as this is a popular way to run a multistore at the moment
- May 12, 2020 at 11:37 am #129888
Ramamurthy Krishnan
Store List search widgets will work in store list page only, it won’t work in any other pages.
