Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Selecting contact info for each vendor
- This topic has 7 replies, 2 voices, and was last updated 8 years ago by
- October 22, 2018 at 10:21 pm #34608
Felipe
GuestHello,
How can i select which vendor contact details are hidden or displayed?I tried in the vendor settings in the admin dashboard, but the vendor can re-select the fields to display his contact info in his own dashboard settings, so as admin i don’t have that control.
It’s important because if vendor pays a higher membership price then he has the chance to display his contact info.
How can i do that?
Thank you.
- October 24, 2018 at 2:23 pm #34757
Vendor may control those but if Admin set those OFF then vendor setting will not work!
Between, if Admin off those then vendor ca’t even manage those. Are you using latest version of plugins?
If not, please update to latest version.Thank you
- October 25, 2018 at 3:51 pm #34964
Felipe Bernal
GuestI set off in capabilities > market the threo options to show email, phone and address. Then in the store settings (as admin) i checked the boxes hide email”, “hide phone” and “hide address”. But then i go as a vendor and i have the option to set on the checkboxes “hide email”, “hide phone” and “hide address”. Then in the frontend, the three of them appear.
What im doing wrong?
Im using latest version.
Thank you.
- October 26, 2018 at 7:59 am #35039
Ahh … no, you have done this right.
Setting options are same for vendor and admin.
If you want to disable those from vendors then OFF from capability.
- October 26, 2018 at 7:55 pm #35087
Felipe Bernal
GuestHello,
So its impossible to select which vendor can display the contact info? I mean…if i disable it in capabilities then this will set off for all vendors?Thanks
- October 27, 2018 at 1:21 pm #35133
If you want to manage this for individual vendors then you require WCFM Groups addon – http://wclovers.com/product/woocommerce-frontend-manager-groups-staffs/
This allow you to setup capability for each vendors individually.
There is an alternate solution for this as well, disable store visibility setting for vendors by adding this line of code –
add_filter( 'wcfm_is_allow_store_visibility', '__return_false' );Thank You
- October 29, 2018 at 12:10 pm #35236
Felipe
GuestHello,
Could you tell me please where do i have to add that code?
Thank you very much. - October 29, 2018 at 1:34 pm #35247
It’s a PHP code, so kindly add this to your child theme’s functions.php
In case you don’t have any any child theme then add such custom codes using – https://wordpress.org/plugins/code-snippets/
- The topic ‘Selecting contact info for each vendor’ is closed to new replies.
