Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Settings inactive
- This topic has 12 replies, 3 voices, and was last updated 5 years, 9 months ago by
Tiscia.
- September 25, 2019 at 1:24 pm #83555
charles.ouaknine
ParticipantHello, When I am logged in as manager, i cannot change the settings, when I click on settings, nothing happens. All the different settings displays but inactive whenI click on them. How can I access the setting fonction that works. tHANKS
- September 26, 2019 at 3:46 pm #83774
Which setting options? WCFM Global setting options?
Well, managers are allowed edit those.
Please check in Google Chrome Browser console, is there any JavaScript error happening to the site or not!
(What is browser console – https://support.airtable.com/hc/en-us/articles/232313848-How-to-open-the-developer-console)Thank You
- September 26, 2019 at 10:07 pm #83884
charles.ouaknine
ParticipantNo there is indicated that there is no error, either java or other.
- September 27, 2019 at 3:06 pm #84013
MemberWell, then we have to debug this.
Pleas share your site details form here – https://wclovers.com/woocommerce-multivendor-customization/
- October 2, 2019 at 9:46 am #84737
charles.ouaknine
ParticipantThis reply has been marked as private. - October 11, 2019 at 9:28 am #86163
MemberSite URL please.
- October 11, 2019 at 2:02 pm #86282
charles.ouaknine
ParticipantThis reply has been marked as private. - October 14, 2019 at 11:06 am #86752
Thanks, I have just checked.
WooCommerce Multivendor Marketplace – this plugin is out dated, please update this and it will be resolve for you.
- October 14, 2019 at 11:49 am #86771
charles.ouaknine
ParticipantHi, thank you for your response.
In the dashbord there is no plugin to update. Not indicated that the woocommerce multivendor marketplaceIS needs any update. Is there a way to update it automatically or which method do I need to use
Thanks - October 16, 2019 at 12:03 pm #87076
MemberWell, that very difficult to say, this plugin update from wordpress.org. So update notice should be there.
Are you using any plugin for controlling other plugins version and update?You may delete and re-install it’s new version. No worries, no data and setting will be altered.
- October 22, 2019 at 2:01 pm #88225
Tiscia
Participanthi. I have the same problem … in the end was it solved?
- October 23, 2019 at 2:56 pm #88562
MemberWell, this is not in our hand.
We are also shocked why you are not getting update notice from wordpress.org.
This may only happen if plugin’s installation folder name changed!
– You may do the same as we suggested before.
- October 23, 2019 at 4:14 pm #88602
Tiscia
Participanti getting update from wordpress … i have last version 5.2.4
Plugins are all updates
i don’t think that the folder name is changed.
How do i doing to resolve the problem ?!
tnx
- The topic ‘Settings inactive’ is closed to new replies.
