Shop Description not saving first time round
Viewing 9 reply threads
    • #52451
      Jade
      Hi there,
      when I enter a new vendor as admin, the shop description is not being saved the first time around. I have to go back and edit the profile and then it works. Possible bug? I will send a screen recording.
    • #52452
      Jade
    • #52629
      Right, it’s not saving on add new vendor.
      We will take care oft this in next update.
    • #54143
      Jade
      Great – thank you – and I have started having a similar problem with the store name. The first time it will not show on front-end. I have to go to WCFM > Vendors > choose a vendor and just save updates without making changes. Only then it shows the Store Name on front-end. Let me know if it’s clear or you want me to record the steps. Thanks! 🙂
    • #54188
      We have resolved this in latest update, 2.2.6
      Did you updated and checked?
    • #60057
      jadenew
      Hi there,
      thank you for the fix. The description seems to be working. But not the shop name. I am importing users via a plugin – it may have some to do with that? The plugin is this, if that helps: WordPress Users & WooCommerce Customers Import Export(BASIC) by Web Toffee.
      I have to go to the shop profile and re-save settings and then the name shows: https://www.loom.com/share/2b70df11bb294faeabc12bdf58db6af6
      Can you advise? Thank you! 🙂
    • #60231
      Well, Store name is same as user first name/last name.
      I don’t think your user import plugin compatible with any multi-vendor plugin, so it’s not importing vendor users properly.
    • #60472
      jadenew
      I see, so I guess I will just have to save it manually for now. I will get in touch with the plugin developer and maybe he/she can do something about it.
      Thank you for your help! 🙂
    • #60589
      jadenew
      I was going to contact the import plugin developer but I’m not sure it is their plugin’s error. Can you please review this video I made: https://www.loom.com/share/218b12b5ccdd4723a4e75cf44c22dbed
      When I import users, the Store Name is displaying in backend but not in frontend.
    • #60724
      Kindly update WCFM Marketplace to 3.0.5 and take a look.
  • The topic ‘Shop Description not saving first time round’ is closed to new replies.
