Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Shortcodes not working somehow
- This topic has 5 replies, 2 voices, and was last updated 7 years, 6 months ago by
- April 20, 2019 at 11:34 pm #58761
Muckyu
GuestSo I was just trying to test the plugin but I am having trouble getting the shortcodes to work.
The dashboard works fine – but if I try any of the shortcodes such as [wcfm_stores] on one of my pages it just shows:“Oops! That page can’t be found.
Nothing was found at this location. Try searching, or check out the links below.”Am I doing something wrong?
- April 21, 2019 at 6:14 am #58795
Nothing was found at this location. Try searching, or check out the links below.– WP show this message when page is not found, 404
It does not matter whatever is page content. Please be sure you have published that page or not! Is this visible at wp-admin -> Pages
- April 21, 2019 at 10:09 pm #58892
Muckyu
GuestHi, thanks for your reply.
Yes the page is published and all – but the shortcode is still not working.
Only the Dashboard works.
I have the following plugins installed – am I maybe missing some?
WooCommerce
WooCommerce Frontend Manager
WooCommerce Multivendor MembershipOr anything I can try to fix it?
- April 22, 2019 at 10:14 pm #58966
Muckyu
GuestI just want to be able to have a list of stores & a map.
What is the right way to get this to work? The shortcode above does not seem to work at all.
Right now I can only access the stores by clicking on a product from the main page first … - April 22, 2019 at 10:17 pm #58967
Muckyu
Guesthttp://wcfmmp.wcfmdemos.com/stores/
Exactly this is what I want to have.
- April 24, 2019 at 9:26 am #59149
Well, if short code does not work then you will get a empty page but not 404 page.
Please show me screenshot for this page edit screen.
- The topic ‘Shortcodes not working somehow’ is closed to new replies.
