should use PDO and speed to display data
Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Feature Request › should use PDO and speed to display data
Viewing 3 reply threads
    • #42469
      cesar
      Hi there, why you don´t use PDO for access to database? i have searching about this, and wordpress was insterested to implement on 2013, but i’ve serching in the core of 5.0.2 and doesn´t use PDO, so you can implement to access data to your plugin use, meanwhile wordpress catch up.
      Other thing, is the lag to display data on any crud. it’s o lazy.
      my best
    • #42498
      Do you want to access WP database from site ?
      Try this plugin – https://wordpress.org/plugins/ari-adminer/
    • #42566
      cesar
      Not, i mean, every data of vendor/customers site data, are saved in SQLi database, and the connections that you use its just query, one of the most insecure, for other hand, PHP allow use PDO (http://php.net/manual/en/book.pdo.php) that it’s so much more secure, this allow use prepare statement and bindParam to put in the query to database values that you want to ask to DB.
      eg.
      <?php
      $sentencia = $mbd->prepare(“INSERT INTO REGISTRY (name, value) VALUES (:name, :value)”);
      $sentencia->bindParam(‘:name’, $nombre);
      $sentencia->bindParam(‘:value’, $valor);
      // insertar una fila
      $nombre = ‘uno’;
      $valor = 1;
      $sentencia->execute();
    • #42610
      Frankly I am not very comfortable with this.
      We use WP standard for this.
      WP DB object “$wpdb” and it supports all this prepare statement, param etc …
  • The topic ‘should use PDO and speed to display data’ is closed to new replies.
