wcfm-santa
-363Day -21Hr -22Min -30Sec
wcfm-santa
Signup to specific vendor group..
Viewing 5 reply threads
    • #79356
      nan
      HI….
      i have setup 4 different membership subscriptions that i would like to have different capabilities.
      so i have made 4 different groups named the same as the memberships..
      I can manually add vendors to the groups, but is it possible to make it so they are added automatically
      when signing up to the chosen subscription??
      // Nicklas
    • #79660
      but is it possible to make it so they are added automatically when signing up to the chosen subscription??
      – Sure, it automatically happen. Hope you have associate Group with Membership ? https://youtu.be/pO4_9xEzWic
    • #79714
      nan
      Hi..
      Thanks for you feedback, but i had already seen that video and done as the video showed me, but it’s still not working.
      i have setup all the subscriptions using Woocomerce Subscriptions (is that even necessary) and made 4 different subscriptions as “simple subscriptions”
      and made 4 different WCFM memberships and 4 different groups with different capabilities…
      I can get the vendors to have the capabilities that i have attached to the group if i select them manually as in the screenshots.
      but i can still make it so it does it automatically..
    • #79949
      Please edit Membership plans and check under “Capability” tab. Be sure you have associate Group there – https://ibb.co/ykvWkrS
    • #80609
      nan
      Hi…
      I have already done that 🙂
      I really really can’t see what’s wrong with this, i have done as per your video and all..
      Is it possible for you to login and have a look?
    • #80801
      Your setting is perfect.
      Do you have register for any membership after this setting?
      Vendors are not automatically associated with group?
      Between, do you have enabled “Require Approval” for vendor registration? If so, then check after registration approve!
      If still not working then please share your site access with me here – https://wclovers.com/woocommerce-multivendor-customization/
      I will check this.
