Single Product Multi-vendor? How it's work?
Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM › Single Product Multi-vendor? How it's work?
Viewing 7 reply threads
    • #36621
      akos
      I’m testing your plugin, but I’m don’t know the “Single Product Multi-vendor” how it’s work. I’m check the documentation (https://wclovers.com/knowledgebase/wcfm-marketplace-single-product-multi-vendor/), but if I’m going to the Products -> “Product” > Vendor I’m only chouse one vendor, and no more. I’m check your demo, and I’m see a same problem…
      What is the problem? Can you help me?
      Best regards,
      Akos
    • #36622
      Hope you have found this image in that documentation – https://ibb.co/gxOtvL
      Admin can not assign one product to many vendors.
      It works as vendor login.
      you have to login as vendor and check another vendor’s product or admin’s product – you will see “Sell this item” option, just click on that.
    • #36623
      akos
      Wow! Thanks the fast help! And how can I show all vendors in the product page in the description? Below the product name, and not in the More Offers.
    • #36624
      You are welcome 🙂
      Well, there is no such setting option but this can be possible to achieve by adding this code snippet –
      add_action( 'woocommerce_single_product_summary',	function() {
      	global $WCFM, $WCFMmp, $product;
      	if( $WCFM && $WCFMmp && apply_filters( 'wcfm_is_pref_product_multivendor', true ) ) {
      		echo '<h2>' . apply_filters( 'wcfm_product_multivendor_tab_title', __( 'More Offers', 'wc-multivendor-marketplace' ) ) . '</h2>';
      		$WCFMmp->wcfmmp_product_multivendor->wcfmmp_product_multivendor_tab_content();
      }, 26 );
      add_filter( 'woocommerce_product_tabs', function( $tabs ) {
      	if( isset( $tabs['wcfm_product_multivendor_tab'] ) ) unset( $tabs['wcfm_product_multivendor_tab'] );
      	return $tabs;
      }, 150 );
      This will such view – https://ibb.co/hwhdvL
    • #36632
      akos
    • #36812
      This is just matter of CSS tweak.
      You may add your CSS to make this look like your preferred screenshot (https://wclovers.com/wp-content/uploads/2018/11/storage.png).
      Thank
    • #36866
      akos
      And how to show stock quantity? If I’m buy the WCFM – Ultimate it’s shows vendor warehouse inventory / quantity?
    • #36914
      Stock is part of WooCommerce, and it’s display depend on single product page template.
      It does not depend on WCFM or WCFM ultimate.
      Well, WC has some setting for showing stock in frontend – https://ibb.co/fNVtLL
      You will find this at wp-admin -> WooCommerce -> Setting -> Products -> Inventory
  • The topic ‘Single Product Multi-vendor? How it's work?’ is closed to new replies.
