Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Feature Request › Single product multivendor
- This topic has 2 replies, 2 voices, and was last updated 7 years, 9 months ago by
- February 7, 2019 at 11:40 am #47012
Venu v
GuestIt’s great to be a part of wcfm marketplace plugin
I have a request for a feature
Single product multivendor according to this for example
Consider vendor ‘A’. adds the product for rupees 50 and it is also sold by vendor ‘B’ for rupees 100 . and vendor B got the order how to split a payment between vendor A and B and admin commission. - February 7, 2019 at 2:07 pm #47029
Neno
GuestHello, Rob, I think this is some kind of Dropshipping model right?
well then is better vendor B to make this order from the customer and after that to buy the same product from vendor A .. and on shipping address, you will put your costumer’s address.
this is only my solution 🙂 maybe there is another solution form our support - February 7, 2019 at 3:41 pm #47053
– This does not work like this. As Vendor B start selling vendor A product it becomes a separate product for vendor B, with separate cost and stock.
Now, if custom purchase vendor A’s product then total commission will go to vendor A, vice versa for vendor B.Well, please check this as well – https://wclovers.com/knowledgebase/wcfm-marketplace-single-product-multi-vendor/
- The topic ‘Single product multivendor’ is closed to new replies.
