Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Membership › Skip Registration for registered vendors
- This topic has 7 replies, 2 voices, and was last updated 7 years ago by
- August 19, 2018 at 11:11 pm #28916
d-n-13
Is it possible to skip the registration step as there is no reason for it for existing vendor, at least for me https://imgur.com/6JXAKRu
Maybe registration page and membership page should be separate
Than You
- August 20, 2018 at 3:53 am #28935
This is required specially for “Store Name”.
In wordpress a user may register just by email address, but for a vendor this is not enough.
Membership and normal registration is separate but same form used both the cases.
- August 20, 2018 at 10:43 am #28957
d-n-13
I have my vendors’ membership ends every month (for testing every 1 day) after that they have to resub to a membership again, other than first time membership why would they put all information again ? they have all info in database already. Do you understand what I mean ?
- August 20, 2018 at 11:11 am #28968
They don’t have to put any additional info.
Registration form comes but it’s already auto-fill.Previously there was an issue in WCFM Membership, if membership switch then profile data reset.
But this has been already resolved in WCFM Membership 2.1.2So, all previous info will be there in profile with membership switch.
- August 20, 2018 at 11:27 am #28971
d-n-13
“They don’t have to put any additional info.
Registration form comes but it’s already auto-fill.”Yes it is coming auto-filled and it is working perfectly. But is there any way to skip this registration form step for existing vendors ? (it is a bit confusing for vendors to resub to membership again if they don’t understand how it works like us) If it is not so simple then maybe in the future.
- August 20, 2018 at 11:32 am #28972
MemberUnderstand you point.
We will definitely look into this, if possible then will definitely discard this step for membership switch.
- August 20, 2018 at 1:48 pm #28987
d-n-13
“We will definitely look into this, if possible then will definitely discard this step for membership switch.”
And “Disabled Vendors” role too, because they’re my vendors who need to resub.
- August 20, 2018 at 1:53 pm #28991
MemberYeah right!
- The topic ‘Skip Registration for registered vendors’ is closed to new replies.
