Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Vendors › Some issues/bugs to resolve
- This topic has 8 replies, 3 voices, and was last updated 6 years, 9 months ago by
- March 15, 2019 at 10:02 am #52809
FuBendu
Participant1 – When a vendor is disabled – his shop staff remains active.
2 – When a vendor updates store policies in Store settings->Store Policies, the vendor is losing his logo.
3 – When vnedor leaves the policy fields empty – these get “<p><br></p>” stored in them – this is undesirable for template rendering
B - March 16, 2019 at 9:13 am #52942
MemberWe are checking this!
- March 19, 2019 at 12:21 am #53370
Craig
ParticipantIn addition to this.
There are only two options for when a vendor cancels membership.
-Disable Vendor User
-Assign Basic MembershipHow do we get that account back to “customer” status.
Can there be more options in the cancel rules to make them a “customer”?Attachments:
You must be logged in to view attached files. - March 19, 2019 at 12:35 am #53373
Craig
ParticipantAlso I note that when a “disabled” vendor re-registers a membership their account still has the “disabled vendor” account status. I think it should change their account to a vendor correct? because they can not get to their dashboard.
I do not see the system changing that status from “disable vendor” to “store vendor” automatically. Should it not be doing that?
- March 19, 2019 at 7:12 am #53426
- March 19, 2019 at 5:33 pm #53571
How a disable vendor again re-register?
- March 19, 2019 at 6:06 pm #53577
Craig
ParticipantYes. When a vendor cancels their membership – their account is automatically changed from “shop vendor” to either “disable vendor” or “assign basic membership” (depending on the rule set in Membership settings for canceled membership) See screenshot.
Is that account then stuck with the account status of “disable vendor”?
What if they want to be a customer and keep shopping on the site? or in 6 months decide they want to sign up on a membership again using the same account?
Most people only use one or two email addresses so to block them from signing up again is not a good idea.Attachments:
You must be logged in to view attached files. - March 19, 2019 at 6:09 pm #53579
Craig
ParticipantCan you add more options to the Membership settings for canceled membership so we can turn them back to a “customer” rather than a “disable member”? What is the purpose of the disable member status?
- March 20, 2019 at 9:28 am #53651
MemberCan you add more options to the Membership settings for canceled membership so we can turn them back to a “customer” rather than a “disable member”? What is the purpose of the disable member status?
Well, disabled vendor users may also access site as customer, no restriction on this. But we have to apply a special role to those users for identification purse!
- The topic ‘Some issues/bugs to resolve’ is closed to new replies.
