Sometimes vendor's can't publish products
Viewing 1 reply thread
    • #36504
      Katherine Reynolds
      Hi
      I want vendors to be able to publish and update products without review. Sometimes the system lets them be published with the submit button, sometimes the system doesn’t and instead shows the submit for review button. I don’t understand why this is! How can I make sure they always have the submit button?
    • #36516
      “submit for review” button only visible if vendor has no permission to publish product directly.
      These setting option comes under WCFM Capability – https://ibb.co/bwtjiV
      Between, hope you are not using any other user role editor plugin!
  • The topic ‘Sometimes vendor's can't publish products’ is closed to new replies.
