Specification product Tabs From Theme Electro is not work.
Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Specification product Tabs From Theme Electro is not work.
Viewing 5 reply threads
    • #50640
      cousinr
      Hello… I use Electro Theme which adds two tabs to product edit screen (1 – specifications and 2 – accessories).
      However, WCFMU does not recognize these tabs. How can I get WCFM to recognize these tabs. Please note these tabs are part of the theme and do not require the installation of additional tabs. The specification tab has a checkbox that includes displaying a tab on the product page. If it is not pressed, the specification tab will not appear.
      The Woocommerce Tab Lite plugin it does not suit me. I need to display only these tabs. I tried to add this two tabs using WCFM custom fields, but my idea failed.
      Please suggest how I can get WCFMU to recognize these two product tabs so that they show up in the product add/edit front-end for vendors?
      Thank you very very very very very very very very very very much.
    • #50702
      “The specification tab has a checkbox that includes displaying a tab on the product page.”
      – Where this checkbox setting exist? Please show me screenshot!
      • #50718
        cousinr
        Как вам прикрепить картинку? В этом поле нет возможности её прикрепить…..
    • #50731
      Upload here and share with us – https://imgbb.com/
      • #51116
        cousinr
        https://ibb.co/LJTpKMR
        1 / This includes the characteristics tab and it adds the attributes specified in the attributes.
        2 / This adds additional description text in the characteristics tab above the attributes.
        A – accessories tab
        B – characteristics tab
        Пока я с вами переписывался, обнаружил следующее – если активировать несколько атрибутов, то вкладка характеристик автоматически появляется на странице товара. НО! Текст описания над характеристиками добавить нельзя. ((( А вот вкладка “аксессуары” (с этим товаром рекомендуем купить product+product) не нашел…..
    • #51146
      Well, you may create such custom tabs under WCFM dashboard easily using WCFM Custom fields – https://wclovers.com/knowledgebase/wcfm-custom-fields/
      • #51195
        cousinr
        Я могу создать пользовательское поле для характеристик, но тогда будет видно оно во всех вкладках, а это бессмысленно. А аксессуары так вообще не понимаю, как их включить…
    • #51194
      cousinr
      Я могу создать пользовательское поле для характеристик, но оно тогда будет видно во всех вкладках, а нужно только во вкладке характеристики. То же самое с аксессуарами, вообще не понятно как их включить…
    • #51431
      Right, I do not ask you to create any custom fields.
      Create custom fields exactly same as you have at wp-admin -> product manager -> characteristics tab
      Use same meta keys.
  • The topic ‘Specification product Tabs From Theme Electro is not work.’ is closed to new replies.
