wcfm-santa
-361Day -13Hr -29Min -32Sec
wcfm-santa
Status Updated notification not working
Best Multi Vendor Marketplace Plugin for WordPress Forums WCFM – Ultimate Status Updated notification not working
Viewing 20 reply threads
    • #57713
      wwsAdmin
      Hi all,
      Status Updated in notification is not working for Admin. i have kept it on for admin and off for vendor.
      If i keep on for vendor, vendor gets all the notification. It is not working for admin.
      Notification like Payment Failed, Order failed ….
    • #57809
      – Well, WCFM has no notification for such conditions for Admin.
      WC has such email notification for Admin, please be sure those are enable at WC Email Setting.
    • #58328
      wwsAdmin
      PFA, Status update am talking.
      when enabled for vendor they starts getting cancelled order email.
      But Admin is not getting
    • #58479
      djks74
      Sorry, its woring for me, but will double check again!
    • #58518
      Thanks for the update, please know me.
    • #58573
      djks74
      Tested….
      Notifcation is working on admin status updates and email also sent to the right notif on email settings.
      but will notify again if something happend. 🙂
      cheers….
    • #58685
      Great … thanks for the update 🙂
    • #58946
      wwsAdmin
      Mostly for failed order am not able to get, where as vendor gets the email when turned on
    • #59002
      djks74
      Hi shubhams,
      Failed or Canceled?
      How to get a failed order by any chances?
      for me, if customer not pay yet then it will be canceled and email goes to all (admin, customer and vendor)
      so when it failed I never get any email because I never got failed orders. can you descrive how to get failed orders?
      so I will try to reproduce it if its working or not. Thanks.
    • #59136
      Well, failed and canceled order are by default disabled for vendors.
      Actually, vendor order does not generate for such order status.
      But, vendor may receive email for these order as email send out as soon as order placed, but WooCommerce later mark those cancelled or failed depending upon payment gateway notification (IPN).
    • #59492
      wwsAdmin
      HI @djks74, it is cancelled.
      You have received a new notification:
      #13195 order status updated to Cancelled
      Check more details here.
      this message.
      @wcfm
      if i enable Status Updated in notification , for vendor it works fine. but Admin is not able to receive even though its on.
    • #59641
      Well, is this status change done by Admin? If so, then Admin will not receive any notification.
      But of vendor change order status then Admin will receive notification for that.
    • #59679
      wwsAdmin
      Status changed automatic. You go to payment portal page and either u cancel or close tab.
      Then after soome time status change.
    • #59821
      Yeah right, WC auto cancel this.
      Well, WC has an email for this to Admin – https://ibb.co/QdFtKdn
      Is this not working ?
    • #59986
      wwsAdmin
      Nope this is also not working,
      I think this the culprit right ?
      thanks
    • #60218
      Do you have any other plugin to control WC order status?
    • #60259
      wwsAdmin
    • #60314
      OK, this plugin has no effect on “cancelled orders”
      Do you have this plugin installed ? https://wordpress.org/plugins/wp-mail-logging/
      No email triggered for “cancelled orders”?
    • #60449
      wwsAdmin
      No i haven’t installed wp-mail-logging, should i do it ?
      Yes no email triggered.
    • #62758
      wwsAdmin
      Any update ?
    • #63424
      djks74
      Dear shubhams,
      have you try to install these 2 of Notification plugin?
      1. Manage Notification E-mails By Virgial Berveling | View details
      2. Notification By BracketSpace | View details
      The only I cannot get notification is for vendor site on push notification (app) and I still testing it. email notif is all good.
      Sandi
  • The topic ‘Status Updated notification not working’ is closed to new replies.
