Black Friday
05Day 04Hr 15Min 30Sec
Black Friday
Stock Management Issue
Viewing 5 reply threads
    • #29978
      d-n-13
      I managed to do a bug by mistake it gave me this error : https://www.dropbox.com/s/b6dn4fqrh5omiou/stock%20-1.JPG?dl=0
      what I did is :-
      1- stock was 0 I wanted to increase the stock so I went to Edit Translated Product (not quick edit), I changed the number but nothing changed, it stayed 0 (I think because it is translated product).
      2- I tried to Quick Edit same translated product, it was successful, I added 10 to the stock.
      3- I bought 1 item successfully.
      4- I tried to buy same item again it tells me it is -1 I cannot buy it.
      after that I went to quick edit default / original product and it was successful with no problems.
    • #30146
      ** Quick edit updated product successfully but stock was not updated I guess. That’s why it still had “0” stock and after purchase it’s stock goes to “-1”
    • #30148
      d-n-13
      So it is a real issue ?
      will you fix it in future update ?
    • #30234
      Actually, WooCommerce only consider main product’s stock.
      Translated product’s stock has no value.
      Max we can disable stock manage for translated products!
    • #30241
      d-n-13
      “Max we can disable stock manage for translated products!”
      Maybe disable everything that cannot be changed in the translated products when you try to edit them, I think only few fields can be changed like product name description etc, better make it simple not to confuse vendors.
      And when I was using Dokan I used to have to translated every product as admin, but wcfm is a life saver with this great feature !!
    • #30458
      Yeah right, that will good to disable unnecessary things for edited products.
      Will do that!
  • The topic ‘Stock Management Issue’ is closed to new replies.
