Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › store credit
- This topic has 10 replies, 4 voices, and was last updated 6 years, 5 months ago by
mdanesfarrarons.
- April 4, 2020 at 6:41 pm #115349
cblack
ParticipantSome of my vendors have sold CSA credit already to customers. I would like to reflect that with Store Credit in their store. How can I do this?
thanks!
Christina Black - April 5, 2020 at 11:03 am #115556
What is “Store Credit”? Are you using third party “wallet” plugin for the purpose?
- April 6, 2020 at 6:40 pm #115949
cblack
ParticipantI don’t have a way to offer store credit, but I want to. Do you have a way to do this? Do you have a 3rd party plugin to recommend?
Christina Black
- April 8, 2020 at 4:22 pm #116864
Ramamurthy Krishnan
Sorry didn’t get your requirement. Can you please elaborate a bit more?
- April 8, 2020 at 4:29 pm #116867
cblack
ParticipantI want Farmer 1 to be able to give a store credit of $50 to one of his customers. “store credit” means the same as a “gift card”. I don’t want the customer to be able to use this credit for Farmer 2’s store.
Can this be done in WC ? If not, do you have a recommendation?
Christina
- April 10, 2020 at 1:33 pm #117583
Ramamurthy Krishnan
You can create coupons to achieve this. Vendors can create their coupons and send it to customers and those customers can apply that coupon while purchasing that particular vendors products only.
- June 6, 2020 at 11:31 pm #139147
mdanesfarrarons
ParticipantBuenas Molay, Justo quiero hacer esto que dices. Un cupon que sirva solo para cada tienda. es decir que solo pueda aplicarse con productos de una tienda. Pero por defecto si pongo otros productos de otras tiendas me lo acepta. Hay alguna forma para hacer esto???
Gracias - June 8, 2020 at 11:54 am #139473
Ramamurthy Krishnan
KeymasterHi @mdanesfarrarons,
Yes you can apply coupon if there is products from other vendors also. The discount will be deducted from that particular vendor whom the coupon belongs to.
- June 8, 2020 at 1:47 pm #139522
mdanesfarrarons
ParticipantA vale! No lo veía porque mi intención era hacer cupones de envió gratuito dependiendo de la tienda. Y si solo hago esto me lo aplica a todo. Esto es posible? o con algún otro plugin
Gracias- June 8, 2020 at 5:53 pm #139589
Ramamurthy Krishnan
Didn’t get your query. Can you explain it please?
- June 8, 2020 at 9:19 pm #139677
mdanesfarrarons
ParticipantHola Molay,
Por supuesto, En principio quiero hacer cupones solo para envíos gratuitos. Pero que cada cupón sirva para un proveedor en concreto. Y solo deje utilizarlo con sus productos. Si hay productos de otro proveedor en el carrito que no funcione. Espero que me haya explicado mejor! Gracias
- The topic ‘store credit’ is closed to new replies.
