Poila Boishakh
Celebrate Poila Baisakh with upto 20% OFF - A Fresh Start, A Great Deal!
00Day 00Hr 49Min 14Sec
Poila Boishakh
Store Manager Menu options not wrapping text
Best Multi Vendor Marketplace Plugin for WordPress Forums WC Marketplace Store Manager Menu options not wrapping text
Viewing 6 reply threads
    • #72581
      htorohn
      I’m having an aesthetic problem with the menu of the store manager. Since I have my site in spanish, there is an option called “Libro de Contabilidad” which is longer that the available space on the menu, thus overlapping with the option below it (please see attached image).
      can you help me get a workaround to fix this issue?
      many thanks in advance.
    • #72686
      Well, this is because of too long name for menu.
      Can you please add this to your child theme’s functions.php –
      add_filter( 'wcfm_is_allow_menu_lable_length', function( $length ) {
      	return 18;
    • #72692
      htorohn
      Hi, Thanks for you reply.
      I added the code to the child theme, but nothing happened. It looks the same.
      Is there a way to change the text of the menu option?
    • #72759
      – yeah sure, you may do this from WCFM Admin Setting -> Menu Manager
    • #72843
      htorohn
      Thank you very much for your response.
      That options does not appear on the menu manager and for what I see, I can only change the original label. what I would need to change is the spanish translation which is the long text, how could I change that?
    • #72844
      htorohn
      Nevermind, I manage to change it with Loco Translate plugin.
      Thanks for all your help
    • #72948
      Great .. thanks for the update!
  • The topic ‘Store Manager Menu options not wrapping text’ is closed to new replies.
