Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM › Store Recent Articles Widget and Store side bar.
- This topic has 4 replies, 2 voices, and was last updated 5 years, 4 months ago by
Ramamurthy Krishnan.
- April 21, 2020 at 3:41 pm #121316
david_kogan
ParticipantI don’t have the Store Recent Articles Widget.
Also, the Store sidebar is not showing. I mean I have a sidebar that works for the vendor’s page but the text is wrong.
Is there a way to inject the widget via PHP?
You must be logged in to view attached files. - April 21, 2020 at 4:10 pm #121326
david_kogan
ParticipantOK Again the german translation is not good.
- April 21, 2020 at 4:12 pm #121327
david_kogan
ParticipantWOW ok
Store Recent Articles is translated into -> “Zuletzt angesehen”. This is last viewed.
Better would be no Translation than a very very bad one. - April 21, 2020 at 4:31 pm #121331
david_kogan
ParticipantAs I see in the code right now there should be a
articles
tab.This is not showing for my vendors.
- April 21, 2020 at 7:56 pm #121411
Ramamurthy Krishnan
The articles tab is not a default feature of WCFM.
Can you please tell us which theme are you using? Then we can suggest you the code snippet for the articles tab for vendors.Thanks,
