Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Store Slug And Limiting Store Slug Changes
- This topic has 7 replies, 2 voices, and was last updated 7 years, 2 months ago by
- August 21, 2019 at 9:44 am #77621
official
Participant1. How can I delete the “-” character in the new vendor registration form? For example: Store name “Ex Store” will produce “domain.com/slug/ex-store”.
2. How can I limit the replacement of the store slug in the vendor settings dashboard? For example: it can only be replaced once.Thank You
You must be logged in to view attached files. - August 22, 2019 at 5:14 pm #77831
add_filter( 'wcfm_generated_store_slug', function( $store_slug ) { $store_slug = str_replace( '-', '', $store_slug ); return $store_slug; }); add_filter( 'wcfm_is_allow_store_slug', '__return_false' );Add this code to your child theme’s functions.php
- August 24, 2019 at 3:41 am #78090
official
ParticipantThen when the vendor changes the membership plan, they can change the store slug again (following the store name).
So how can I remove the Store Name field from the membership plan? But is the Store Name in the vendor settings NOT REMOVED?
- August 29, 2019 at 11:40 am #78938
Well, you asked me code for removing “Store Slug”, do you want to remove “Store Name” as well?
Between, this code will applicable on all membership plans.
- September 3, 2019 at 1:49 am #79735
official
ParticipantOkay, send your code.
- September 4, 2019 at 8:34 am #79954
Use this code –
add_filter( 'wcfm_is_allow_store_name', '__return_false' );Thank You
- September 5, 2019 at 2:19 am #80137
official
ParticipantWhen I use the code, new vendors cannot enter the store name (First register).
So what I mean is: That vendors have registered on my site, they can’t change the store name when they want to increase / change store membership.
- September 6, 2019 at 4:41 pm #80442
Please use this updated code –
add_filter( 'wcfm_is_allow_store_name', function( $is_allow ) { if( is_user_logged_in() ) $is_allow = false; return $is_allow; });Thank You
- The topic ‘Store Slug And Limiting Store Slug Changes’ is closed to new replies.
