Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Marketplace › Store Vendors list & Products lists are not appearing in Dashboard
- This topic has 8 replies, 2 voices, and was last updated 5 years, 8 months ago by
tradeshamim.
- December 3, 2019 at 12:07 am #95666
tradeshamim
Hope you are doing fine. My dashboard was fine earlier and haven’t checked for couple of days.
But there is a problem now:No product, vendors’ list or media appears when I click on Products, vendors list or media respectively (Screenshot attached). Theme I am using is kleo and once again, it was fine earlier.
Could you help me solve the issue.
You must be logged in to view attached files. - December 7, 2019 at 12:17 pm #96394
MemberPlease check at wp-admin -> WooCommerce -> Status -> Logs -> fatal_erros log -> is any error generated?
Also check in Google Chrome Browser console, is there any JavaScript error happening to the site or not!
(What is browser console – https://support.airtable.com/hc/en-us/articles/232313848-How-to-open-the-developer-console) - December 8, 2019 at 5:33 pm #96591
tradeshamim
The initial problem was relating to cache plugin, as dashboard now works after disabling those plugins. However, though the issue mentioned earlier is resolved, the site is having different problem now.Variable product type does not appear in the drop down list of the Vendor. Meaning a vendor cannot add variable product, though from the capability it is enabled.
(1) Error -1
From Woocommerce error logs the following error appears:fatal-errors-2019-12-08-6cccee4a85849410f6804ff65cddc3ea.log Delete log
View
2019-12-08T09:04:16+00:00 CRITICAL Uncaught Error: Call to undefined function Automattic\WooCommerce\Admin\Features\wc_get_screen_ids() in /home/comdmeng/public_html/wp-content/plugins/woocommerce-admin/src/Features/Onboarding.php:616
Stack trace:
#0 /home/comdmeng/public_html/wp-includes/class-wp-hook.php(288): Automattic\WooCommerce\Admin\Features\Onboarding->update_help_tab(Object(WP_Screen))
#1 /home/comdmeng/public_html/wp-includes/class-wp-hook.php(312): WP_Hook->apply_filters(NULL, Array)
#2 /home/comdmeng/public_html/wp-includes/plugin.php(478): WP_Hook->do_action(Array)
#3 /home/comdmeng/public_html/wp-admin/includes/class-wp-screen.php(412): do_action(‘current_screen’, Object(WP_Screen))
#4 /home/comdmeng/public_html/wp-admin/includes/screen.php(241): WP_Screen->set_current_screen()
#5 /home/comdmeng/public_html/wp-content/plugins/jetpack/vendor/automattic/jetpack-sync/src/class-sender.php(365): set_current_screen(‘sync’)
#6 /home/comdmeng/public_html/wp-content/plugins/jetpack/vendor/automattic/jetpack-sync/src/class-sender.php(457) in /home/comdmeng/public_html/wp-content/plugins/woocommerce-admin/src/Features/Onboarding.php on line 616Error-2
geoip-2019-12-08-21c0cfadd6153b05a88a0897586cdd4f.log
2019-12-08T00:00:41+00:00 WARNING The value “” is not a valid IP address.
2019-12-08T00:15:17+00:00 WARNING The value “” is not a valid IP address.
2019-12-08T00:30:31+00:00 WARNING The value “” is not a valid IP address.
2019-12-08T00:45:16+00:00 WARNING The value “” is not a valid IP address.
2019-12-08T01:00:45+00:00 WARNING The value “” is not a valid IP address.
2019-12-08T01:15:47+00:00 WARNING The value “” is not a valid IP address.Not sure if the above errors have anything to do with the issue. Hope you can also help resolve the issue. Hope this time you can get back with an answer a bit early. Thanks.
- December 9, 2019 at 2:06 pm #96727
Are you using all plugins at latest version?
Please enable “WooCommerce Admin” plugin, it has many issues.
- December 9, 2019 at 4:46 pm #96747
tradeshamim
Thanks for quick response. All the plugins are updated to date. And Woocommerce Admin plugin is enabled (I also tried disabling the plugin), but no result. Yes there were issues relating to Woocommerce admin Plugin, but they have fixed it almost instantly by releasing update.As I mentioned earlier, My current issue is only about capability of Vendor to add VARIABLE PRODUCT. The type Variable product does not appear in the drop-down menu.
However, Admin can add variable product. From the capability setting, variable product is allowed for vendor.
Screenshots attached. If you need login credentials to check, kindly let me know.
You must be logged in to view attached files. - December 10, 2019 at 10:01 am #96830
MemberOK, are you using WCFM – Group & Staff addon?
Between, which multi-vendor plugin you are using for the site? WCFM Marketplace (https://wordpress.org/plugins/wc-multivendor-marketplace/), or some other one?
- December 10, 2019 at 5:19 pm #96884
tradeshamim
ParticipantNo brother, I am not using- WCFM – Group & Staff addon;
AND
I am certainly using WCFM Marketplace Multivendor Plugin.
Thanks for your prompt response. Awaiting a solution to this issue.
- December 12, 2019 at 9:30 am #97171
MemberOK, please be sure you didn’t OFF “Attributes” capability by mistake – https://ibb.co/Fwxtdsv
It’s essential for creating Variable products.
- December 17, 2019 at 6:18 pm #97779
tradeshamim
Couldn’t update you. The issue was relating to Attributes option. That was unchecked. You may close the topic.
- The topic ‘Store Vendors list & Products lists are not appearing in Dashboard’ is closed to new replies.
