Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › Stripe Calculation error with admin coupon code
- This topic has 4 replies, 2 voices, and was last updated 6 years, 7 months ago by
- January 16, 2020 at 5:28 am #102237
vanilladev89
ParticipantHello
Tested Stripe Direct with Admin coupon codes and found an error in the application fee.
For ease of numbers we are using a commission percentage plus fixed of 5% + $.25
With a sale of $10 the application fee should be $.75. This also means that with Commission after consider Admin Coupon? not checked, the commission should be the same.. $.75. This is true if there is no admin coupon.
However, if the “Commission after consider Admin Coupon?” is not checked and you apply an admin coupon code, the stripe payment subtracted the $.25 and the application fee is being recorded as $.25 instead of $.75.Thanks
- January 16, 2020 at 5:48 am #102238
vanilladev89
ParticipantTested Vendor Coupons after the Admin coupons and the calculations appear to be off with this as well
Same commission 5% + $.25
Results:
No coupon $.75
10% coupon applied ( making sale of $9 ) Commission after consider vendor Coupon? checked $.70
10% coupon applied (making sale of $9 ) Commission after consider vendor Coupon? not checked $.25 ( should be $.75 )Am I misunderstanding how this works?
- January 19, 2020 at 3:12 am #102672
vanilladev89
ParticipantThis is also happening with the new Transactional fee
Sale of $10 with 10% coupon applied, consider vendor coupon not activated. Commission is set to 5% and transactional charge set to 2.9%+$.30
Total commission sent to Platform Account should be $1.08. Total amount of sale is $910x.05=$.50
Transactional fee takes fee after vendor commission so 9.5x.029+.30= $.57.5
Total Fee that should be transferred to platform account $1.08
Actual amount transferred to platform account $.08 - January 26, 2020 at 11:18 am #103934
Kindly show me your Commission setting screenshot.
If you have set commission at vendor or membership or product or category level then show me those as well.
Also show me this order details screenshot from vendor’s account.
- January 26, 2020 at 11:19 am #103935
MemberTransactional fee takes fee after vendor commission so 9.5x.029+.30= $.57.5
– Show me “Transaction Fee” setup setting screenshot as well.
- The topic ‘Stripe Calculation error with admin coupon code’ is closed to new replies.
