Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM › Stripe Connect
- This topic has 15 replies, 2 voices, and was last updated 8 years, 5 months ago by
- May 6, 2018 at 2:29 pm #22881
Ed Stack
My multivendor site is working with WC-Marketplace and I am using WCFM for the vendor frontend dashboard. When using WC-Marketplaces frontend dashboard I can connect to stripe no problem but I cannot connect vendors to stripe using WCFM. Is WCFM not working with Stripe? Can you please help me to resolve this issue?
Thanks and Regards
Ed
- May 7, 2018 at 11:05 am #22921
No, WCfM works with WC Marketplace Stripe connect.
We are testing the things once again and let you know.
- May 7, 2018 at 11:22 am #22922
Hope you created Stripe Client ID for the purpose, but you have added as return / redirect URL?
Kindly set this WCfM dashboard setting page URL.Thank You
- May 9, 2018 at 12:28 pm #23065
Ed Stack
GuestThis reply has been marked as private. - May 9, 2018 at 4:07 pm #23075
I think it’s still redirect URL issue.
Which URL you have set over there? Is this WCfM dashboard setting page URL!
- May 9, 2018 at 5:39 pm #23082
Ed Stack
GuestThis reply has been marked as private. - May 12, 2018 at 6:22 am #23163
This is WCfM dashboard page settings page, right?
Then it should work.
- May 14, 2018 at 11:15 pm #23340
Ed Stack
GuestThis reply has been marked as private. - May 14, 2018 at 11:17 pm #23341
Ed Stack
GuestThis reply has been marked as private. - May 14, 2018 at 11:38 pm #23345
This works perfectly, and test mode is not an issues.
I think encoding is causing the issue.
Can you please try once by some simple url, not required to encode. e.g. https://modapo.com.br/painel-do-vendedor/settings/
- May 16, 2018 at 11:12 am #23389
Ed Stack
GuestThis reply has been marked as private. - May 16, 2018 at 3:12 pm #23408
That’s something strange.
It’s like setting page form submitted as GET request.Is this your live vendor or you are testing this?
We are also checking this once again.
Really sorry for the trouble.
- May 16, 2018 at 5:32 pm #23424
Ed Stack
GuestThis reply has been marked as private. - May 17, 2018 at 12:31 pm #23472
MemberOK, I test the thing and some fix for this.
Can you please delete your WCFM Free plugin and install the one from here – https://drive.google.com/file/d/1vuFjlQsd7mMmvlHADXjaSZ5EJITiQfdp/view?usp=sharing
Don’t worry, these changes will be part of WCFM next update.
Please try this and know me is this resolve the issue or not.
- May 17, 2018 at 5:58 pm #23489
Ed Stack
Thanks.. That works well. I appreciate your help with this!
Regards
Ed
- May 18, 2018 at 6:33 am #23506
MemberFantastic 🙂
You are welcome.
If you ever get a chance then please add a review for us – https://wordpress.org/support/plugin/wc-frontend-manager/reviews/
- The topic ‘Stripe Connect’ is closed to new replies.
