Stripe live payment do not work
Viewing 8 reply threads
    • #100753
      aemr45
      I´m using Stripe split pay, was using a test key and everything worked fine so I decided to disable testing mode, changed test keys and checkbox in both settings (Dashboard and WP Woocommerce).
      The problem is that when I try to subscribe as vendor, in payment section I get the error messege:
      No such plan: here is the live plan ; a similar object exists in live mode, but a test mode key was used to make this request.
      I have tried deleting cache in both WP and browser, changing stripe API key and adding new plans of subscrition in wc lovers memberships, but I always get the same message that a test mode key was used.
      My versions are:
      WCFM – WooCommerce Frontend Manager 6.3.6
      WCFM – WooCommerce Frontend Manager – Groups & Staffs 3.4.0
      WCFM – WooCommerce Frontend Manager – Ultimate 6.3.5
      WCFM – WooCommerce Multivendor Marketplace 3.2.7
      WCFM – WooCommerce Multivendor Membership 2.7.5
      WooCommerce 3.8.1
      WooCommerce Stripe Gateway 4.3.1
    • #101450
      aemr45
      just updated WCFM – WooCommerce Multivendor Membership to 2.7.6
      The error is still happening, please help I need to start this business.
    • #101610
      aemr45
      any idea what could I do? I already deleted all testing vendors and clients, but system still sends the error of test mode key…
    • #101685
      aemr45
      Stripe API version is set to STRIPE_API_VERSION = ‘2019-02-19’ in the file class-wcfm-stripe-api.php, and my stripe account version is up to date = 2019-12-03, can this be a problem??
    • #102100
      aemr45
      Hi, just to let you know it is working now
    • #108625
      sheridandoyle
      How did you get it working if I may ask?
    • #118457
      karl ohin
      Hi
      What did you do to fix this , i have the same issue
      I have the live credentials in the WOO payment settings and the marketplace , but the membership is trying to put the subscription through using TEST
    • #118674
      aemr45
      Sure, what I missed was to configure Stripe live key on Membership -> Settings -> Stripe settings
      I hope this works for you.
      Regards
    • #118736
      karl ohin
      Hi aemr45
      Thank you for your post . I found the answer in there . Thank you for helping 🙂
      Bye for now
  • The topic ‘Stripe live payment do not work’ is closed to new replies.
