Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Marketplace › Stripe Split Payment for Vendors – Stripe payment processing failed:
- This topic has 6 replies, 3 voices, and was last updated 6 years, 2 months ago by
- June 14, 2019 at 8:28 pm #67675
longryder
ParticipantGood evening
I’m hope you can help me from going mad as I’ve spent all day trying to rectify this!
I’ve just installed WCFM and am very impressed. However I am stuck on one issue in my testing phase – paying vendors
From the main menu Settings-Withdrawal settings – I tick Stripe and Stripe Split Pay
Stripe Split Pay Mode – Transfer Charges
Enable Test Mode – Ticked
Stripe Client ID – Is the correct Client ID from my main Stripe Account
Stripe Publish Key – Is the correct key from my main Stripe Account
Stripe Secret Key – Is the correct key from my main Stripe AccountI now register as a vendor and connect my vendor stripe account up to the site via the vendor settings – payment – preferred method type. It says I am now connected with Stripe
I now add saleable products to my new vendor store.
As a customer I can place an order for the products in the new store.
As the site owner I receive the full payment from the customer for his order. At this point I am expecting WCFM/STripe to pay a the vendor his appropriate commission – however this is not happening.
When I look in the Woocmmerce logs I get Stripe payment processing failed: No such destination: acct_XXXXXXXXXX
I also get the following in the Stripe log
Request POST body
“amount”: “10335”,
“currency”: “USD”,
“destination”: “acct_XXXXXXXX”,
“description”: “Split Pay for Order #3688”,
“source_transaction”: “ch_XXXXXXXXXXXXX”
}Response body
“error”: {
“code”: “resource_missing”,
“doc_url”: “https://stripe.com/docs/error-codes/resource-missing”,
“message”: “No such destination: acct_XXXXXXX”,
“param”: “destination”,
“type”: “invalid_request_error”
}The value in acct_XXXXXXX corresponds to the ID of my vendors stripe account. Its as if the vendor stripe account is not fully linked upto the main site account. I thought this happened when the vendor connected his account via the dashboard in WCFM. Would you be able to point me in the right direction as I’m not sure this is a WCFM or Stripe issue
Many thanks
- June 14, 2019 at 8:51 pm #67678
sdel_nevo
You may want the change the charge method
Change to direct charge and try testing again
stripe works really well in this setting, direct charges also mean that the vendor picks up the bill for the gateway fee and refunds
Steve
- June 14, 2019 at 9:06 pm #67679
longryder
ParticipantHi Steve
I’ve just tried that and am now getting the message below when placing the order. It certainly seems that the link between the two Stripe accounts has not been established correctly
Stripe Split Pay Error: The provided key ‘sk_test_********************osyj’ does not have access to account ‘acct_XXXXXX’ (or that account does not exist). Application access may have been revoked.
- June 14, 2019 at 9:18 pm #67680
sdel_nevo
Is your test vendor account different to your stores stripe account
But that I mean your not using the same stripe account for both the site and the vendorDouble check your keys are correct that you are entering
Also
Check that the stripe apis are current and up to dateI had the exact same issue I got in touch with stripe support, dead easy to do via chat they are amazing, they will check the logs for your account and point you in the right direction, for me it turned out that the APIS needed updating as I was unknowingly using very outdated ones
Steve
- June 18, 2019 at 11:04 am #68292
Member@longryder, do you have talk to Stripe support yet regarding this error?
If not, then please talk once!
Thank YOu
- June 18, 2019 at 8:07 pm #68466
longryder
ParticipantI have spoken to Stripe about this error. In the end I have managed to sort with it the help of one of your colleagues who emailed me.
Both the main stripe account and the vendor account need to be in the same mode for the connection to work – test and test or live and live. Once I did that I could see the vendors account as connected and the transfer went through without an error
Thanks for your help
- June 22, 2019 at 4:27 am #68993
MemberGreat … thanks for the update 🙂
- The topic ‘Stripe Split Payment for Vendors – Stripe payment processing failed:’ is closed to new replies.
