Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Marketplace › Stripe with WCFM Marketplace
- This topic has 31 replies, 2 voices, and was last updated 6 years, 10 months ago by
- September 6, 2018 at 8:22 pm #30995
Kevin Ruzbacki
GuestIs it possible to use Stripe Connect with Split Payments solely with WCFM Marketplace? I know there is a plugin called WCMp Stripe Marketplace which allows vendor and admin to receive their split of the payment as soon as it’s made. Is this plugin compatible?
- September 7, 2018 at 6:12 am #31008
MemberHi Kevin,
Well, WCFM Marketplace not yet has this option for split payment.
“WCMp Stripe Marketplace” this plugin is specifically made for WC Marketplace, but if you want to use this we can make it compatible with WCFM Marketplace as well.
Please know me your thoughts.
- September 7, 2018 at 2:43 pm #31066
Kevin
GuestHowever you can make it happen, I want to be able to use Stripe with Split Payments. If making WCMp Stripe Marketplace compatible, we can do that. If you would be able to integrate the feature into your own plugin that would work as well.
- September 7, 2018 at 4:09 pm #31070
Do you have “WCMp Stripe Marketplace” this addon, then please share with us.
We will make this compatible with WCFM Marketplace.
- September 7, 2018 at 4:39 pm #31090
Kevin
GuestAt the moment, no. I wanted to be sure it would be compatible before I purchased. what are the next steps?
- September 7, 2018 at 4:47 pm #31091
Just purchase this and send us.
In any case it will be useful for you, if not WCFM Marketplace then WC Marketplace is there.
And WCFM works with both of them as well.
So just get it!
- September 7, 2018 at 6:34 pm #31115
Kevin
GuestPurchased and installed. Now what do I do?
- September 7, 2018 at 6:54 pm #31122
Please share that plugin with us at wclovers.contact@gmail.com
Or, share your share details with us.
- September 7, 2018 at 7:16 pm #31124
Kevin
GuestThis reply has been marked as private.
- September 7, 2018 at 7:17 pm #31125
MemberYeah right, thank you.
Site URL please.
- September 7, 2018 at 7:20 pm #31126
Kevin
- September 7, 2018 at 7:26 pm #31127
MemberThank you very much.
We will integrate this in next update.
Thanks agin for your cooperation 🙂
- September 7, 2018 at 8:59 pm #31133
Kevin
GuestAny idea on a time frame?
- September 8, 2018 at 4:41 pm #31173
We will add this within 7-10 days.
- September 19, 2018 at 10:27 pm #32056
We will release this by coming weekend.
Thanks for your patience.
- September 22, 2018 at 3:39 pm #32251
We have already integrate Stripe Split payment but not released in latest update (1.1.0)
We are testing this a bit more.This will be release in next update (possibly on coming Tuesday)
Custom payment gateway integration option was essential for this and we have released that in this version – https://wclovers.com/knowledgebase/wcfm-marketplace-custom-payment-gateway-developers-guide/
- September 24, 2018 at 1:12 pm #32366
Here is good news for you, WCFM Marketplace 1.1.1 has just released and we have added Stripe Split pay option in this version.
Please update your and take a look.
Well, I have to mentioned you something. This was not possible for us make WCFM Marketplace compatible with “WCMp Stripe Marketplace” so have developed this our own, sorry I have asked you to purchase that. But not it has no use. I think, you still have few days left to get refund for this as well.
- September 28, 2018 at 8:36 pm #32812
Kevin
GuestHave you had any success connecting a vendor account? It works in test mode, but gets stuck before on Stripe’s connection page before it redirects back to my site live mode. Any ideas?
- September 29, 2018 at 3:21 am #32817
Can you please recheck return URL you have set at Stripe configuration!
It should be WCFM dashboard setting page link.
- October 13, 2018 at 7:50 pm #33934
Kevin
GuestI want the only option be Stripe Split Pay and not have regular Stripe available on the vendor setup wizard, so I don;t have to worry about payouts at all. Is there a way to eliminate the regular Stripe Pay option when they are setting up? Or possible alter the text to include “(Immediate Payments)” next to Split Pay when they are given the option between Stripe & Stripe Split Pay?
- October 14, 2018 at 8:52 am #33969
Whether you are using Stripe or Stripe Split Pay but fro vendor’s “Stripe Connection” is essential.4
Without this how to know vendor’s stripe account and how payment can be transfer there?Hope you understand my point!
- October 15, 2018 at 7:03 pm #34064
Kevin
GuestYes, I understand the point. But if some vendors choose the regular “Stripe” instead of “Stripe Split Pay” then I actually have to go and pay those vendors out at the end of the month because they were given that option. I want everything to be automatic for everyone at the time of sale with Split Pay, by only allowing them to choose Split Pay.
- October 16, 2018 at 2:46 pm #34117
Vendors can’t choose “Stripe” or “Stripe Split Pay” – they only have one have one option “Stripe”.
Please check as vendor login.Well, you just enable “Stripe Split Pay” from admin section -> withdrawal setting.
Between, are you going to have only “Stripe” as payment option for your customers?
- October 17, 2018 at 3:42 pm #34206
Kevin
GuestStripe Split Pay is the only box checked in the admin withdrawal settings. In the actual vendor store settings, yes, the only option is Stripe and they connect their account. But in the quick setup wizard, the vendor has the option to choose between “Stripe” and “Stripe Split Pay” (I could show you, but I’m not sure how to add images in this forum). I just want to give the one option since most people won’t know the difference off hand.
Will selecting Stripe or Stripe Split Pay both activate Split Pay since that’s the only withdrawal method available?
And yes, stripe checkout will be the only payment option available to customers.
- October 17, 2018 at 4:21 pm #34212
I understand the problem.
We will resolve this for setup widget.
- October 20, 2018 at 3:11 am #34399
Kevin
GuestOk please let me know when it is updated
- October 20, 2018 at 6:11 pm #34441
MemberSure, I will know you.
- October 24, 2018 at 4:46 pm #34786
WCFM Marketplace new version has just released and this issue has been resolved.
- October 25, 2018 at 4:59 am #34902
Kevin
GuestI like the fact that there is now only one option on the quick setup wizard as well as the store options on the vendor side, it only shows “Stripe” and not “Stripe Split Pay”. However, on the admin panel when I access the vendor options, I can still change the vendors setting to either “Stripe” or “Stripe Split-Pay”.
In my admin settings, the only withdrawal method I have checked is “Stripe Split-Pay”. Since the vendor can only select “Stripe” and I have “Stripe Split Pay” as the only method for withdrawal, will that automatically override to make all transactions thru “Stripe Split-Pay”?
- October 25, 2018 at 4:27 pm #34967
As a vendor “Stripe” or “Stripe Split pay” is same. Whatever they may choose.
If order placed via Stripe then “Stripe Split Pay” will work.We will take care of this for Admin panel vendor option as well.
- The topic ‘Stripe with WCFM Marketplace’ is closed to new replies.
