Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Membership › Subscriptions for WooCommerce – Not working.
- This topic has 5 replies, 3 voices, and was last updated 7 years, 2 months ago by
d-n-13.
- June 20, 2018 at 4:21 am #25140
d-n-13
I downloaded Subscriptions for WooCommerce plugin as seen in WFCM guide in youtube (WCfM – Membership by WC Products). It allows me to see when subscriptions starts and ends in a good clear list, but it is not working, Admin will not get approval/rejection message, and vendor won’t get a membership.
Is it not compatible anymore ?
Check attached screenshot.
- June 20, 2018 at 4:23 am #25142
d-n-13
ParticipantThis reply has been marked as private. - June 20, 2018 at 4:34 am #25143
d-n-13
ParticipantActually the plugin broke WCFM.. when clicking complete on orders they become “Pending for payment” instead (check attachement), and admin never gets approval msg, vendor never become a member, even choosing other normal membership that isn’t using the plugin, they’re broken !
After deactivating the plugin the vendor was able to subscribe the normal way.
Do you advice me to not use it nor wait for a fix ?
- June 22, 2018 at 5:55 am #25229
Thanks for all the details.
It worked when we integrated that.
I am checking this again.
- June 22, 2018 at 6:48 am #25236
Bingal
I have tested the things in depth and found that “Subscription for WooCommerce” plugin has a serious bug.
If I am updating an order status using Quick Action icon, whether WCfM dashboard or WC default order listing, it removes customer association for that order.
And that breaks the whole system.
But, if you change order status from w-admin order details page then it works perfectly, try this once.
I think they are not aware of this, if we add ticket at their forum they will definitely resolve this.
- June 22, 2018 at 7:40 am #25238
d-n-13
ParticipantHi, thanks for answering.
1- “But, if you change order status from w-admin order details page then it works perfectly, try this once.”
This is not an option, the plugin breaks everything even vendors cannot complete their products from front-end anymore I think.
2- And that breaks the whole system.
I deactivated the plugin for now, will it be okay or you mean wcfm system will be broken and i have to reinstall ?
3- I think they are not aware of this, if we add ticket at their forum they will definitely resolve this.
do I contact them as customer or WClovers will contact them as devs ?
- The topic ‘Subscriptions for WooCommerce – Not working.’ is closed to new replies.
