Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM › syncronize vendor location to products
- This topic has 7 replies, 2 voices, and was last updated 5 years, 4 months ago by
Sarmistha Chakraborty.
- May 26, 2020 at 5:10 am #135232
Gary Funk
Participantre this thread
where do i find this setting??
- May 26, 2020 at 12:02 pm #135290
Add vendor location from vendor WCFM dashboard -> Settings (PFA).
Please be advised the “store address” and “store location” have to be in the same country, state.Thanks.
You must be logged in to view attached files. - June 9, 2020 at 2:53 am #139742
Gary Funk
ParticipantThanks for the reply however it doesnt really answer the question, that is a vendor screenshot not admin screenshot? see my vendor screenshot though for example, it doesnt show like yours.
the same store address and store location will always be the same. however i cant set the store location??? see shot.
also what are the steps to actually make this work (ive added geomywp alread)
You must be logged in to view attached files. - June 9, 2020 at 7:35 pm #139944
It seems like this is happening due to some plugin conflict. Kindly disable all other plugins except WooCommerce and WCFM plugins(updated). and Use default WordPress theme. After that check again “Store location” this option will work or not.
Let me know how it goes.Thanks!
- June 12, 2020 at 10:44 pm #140928
Gary Funk
Participantthanks the lookup seems to work again without changing anything?? that said when i set that, products still dont have their location set to the store location? how do we make that happen automatically.
- June 15, 2020 at 10:20 pm #141491
Sorry, but we didn’t get your issue. Please elaborate with the screenshot.
Did you mean Product search not working with store location?Thanks.
- June 19, 2020 at 4:17 am #142393
Gary Funk
Participantive set the location for the store as per your instructions above.
setting this does NOT set the location on existing products that the vendor has in the system?
- June 21, 2020 at 9:37 pm #143062
If you are using “GEO my WP” plugin for product location,
After you have set vendor store location from vendor settings(https://wclovers.com/wp-content/uploads/2020/05/vendorlocation.png), then this location will get pre-automatically populated by-default in product location tab. (PFA)Thanks.
