Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Marketplace › Table rate does not accept comma spelling in WCFM
- This topic has 7 replies, 2 voices, and was last updated 7 years, 6 months ago by
- June 26, 2018 at 1:08 pm #25474
Toni
I use WCMp, advanced shipping, Table rate and WCFM Ultimate.
Table Rate doesnt accept the comma spelling e.g. 5,90 only with a point 5.90
But in woocomerce Backend table rates show and accept comma. Is it possibly not synchronized in WCFM with woo number settings?
Kind regards
Toni
- June 26, 2018 at 5:18 pm #25495
Can you please show me a screenshot, for which field this is happening?
We will definitely sync this in next update.
- June 27, 2018 at 11:06 am #25554
Toni
ParticipantThat would be great. It happens at the fields: Row cost, Item cost, lbs cost and % cost. See attachement.
In this context, you may also be able to add the following options in the next update for the very important topic shipping:
1. If the Vendor creates a shipping rule with table rat and the result for the shipping costs is 0 (e.g. for free shipping on orders over x), the shipping label that the admin has created (additional field in Admin backend) appears on the product page, shopping cart and checkout.
2. Abort checkbox (table rate function) for Vendors shippingclass. Needed to interrupt one rule e.g. if the customer buys two products, one with a cheap and one with an expensive shipping and the Vendor wants to ship both products in one package. Settings in Table rate backend “Calculation type per shipping class”
3. Admin can activate needed fields, resp. hide unneeded fields in Vendor Dashboard>settings e.g. Label, lbs cost, % cost
4. Admin can allow shipping Label or overwrite (additional field in Admin backend) if it is disabled as described in No.3
5. The design in a row would be recommended, see attachment (screenshoot WCMp). It takes up less space, would be better usable with option No. 3 “hide unneeded fields” and is more user-friendly.
If you already use codes for the above mentioned points, it would be great if you would write them for all of us here.
I am very satisfied with your work, I know it’s not always easy, and I would be happy if I could continue to suggest improvements 🙂
I look forward to your answer.
- June 28, 2018 at 6:43 am #25595
There has some misunderstanding.
You are not using WCfM dashboard. It’s default WC Marketplace dashboard.
Kindly reach that plugin forum for any assistance on this.
- June 28, 2018 at 9:17 am #25597
Toni
ParticipantUnfortunately you misunderstood it. I use WCFM Ultimate.
The first attachment “wcfm_table_rate_use_comma” clearly shows the table rate in WCFM format
The second was just a screenshot to show you how I mean it with “in a row” and what it looks like with WCMP…
Very important next to the comma spelling is point number 1.
I hope you solve the problem and consider my suggestions.
- June 30, 2018 at 10:13 am #25679
We will definitely take care of this in next update.
- June 30, 2018 at 1:16 pm #25690
Toni
ParticipantGreat, thank you!
- July 4, 2018 at 11:17 am #25865
We have resolved “comma” issue in WCfM 4.1.7
Layout change is not yet there, will do this in coming update as well!
- The topic ‘Table rate does not accept comma spelling in WCFM’ is closed to new replies.
