Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Marketplace (WooCommerce Multivendor Marketplace) › The orders are not marking as sending
- This topic has 7 replies, 2 voices, and was last updated 6 years, 8 months ago by
- June 6, 2019 at 4:09 pm #66223
ing.acrd
ParticipantHello, when the vendor mark the order as sent, before there was a red car, so we knew that the order was send by a vendor, but now there only is a note in the order. I tryed that vendor mark the order completed, but when there was an order with products of more than one vendor, an one of them mark as complete, the whole order was mark as complete, so the other vendor didnt see the order processing.
So, i need to see order by order, and mark as complete manually when all verdors shipped the order
Please help me.
- June 10, 2019 at 7:54 pm #66824
– You have to disable “Order Sync” option form WCFM Admin Setting -> Marketplace Setting
- June 14, 2019 at 5:04 pm #67650
ing.acrd
ParticipantHi again,
I disabled “order sync”, and when a vendor mark the order shipped or complete, the same order for another vendor remains processing, thats ok.
But, when all verdors has completed the order, the order is not complete for the admin, so again, i have to see one by one order if was sheep by all vendors and mark it as complete manually.
it is any way that automatically the order change its status to complete or shipped when all vendors in that order, have marked them order as shipped or complete?
- June 15, 2019 at 4:49 pm #67863
Well, first of all WooCommerce mail order has no such status called “Shipped”.
But it’s possible to mark order “Completed” is many conditions.
Tell me, in which condition you want to mark main order status “Completed”?
- June 19, 2019 at 2:44 pm #68616
ing.acrd
The order should be marked as completed automatically, when all the vendors has shipped all the items. Actually, i have to manually check order by order, if all vendors has shipped the items of the order and mark as complete manually. It takes me so many time!
- June 22, 2019 at 5:04 am #69003
Please add this code to your child theme’s functions.php –
add_action( 'wcfm_after_order_mark_shipped', function( $order_id, $order_item_id, $tracking_code, $tracking_url, $product_id, $wcfm_tracking_data ) { $traking_added = false; $order = wc_get_order( $order_id ); $products = $order->get_items(); foreach( $products as $product => $item ) { $traking_added = false; foreach ( $item->get_formatted_meta_data() as $meta_id => $meta ) { if( $meta->key == 'wcfm_tracking_url' ) { $traking_added = true; } } if( !$traking_added ) break; } if( $traking_added ) { $order->update_status( 'completed', '', true ); do_action( 'woocommerce_order_edit_status', $order_id, 'completed' ); } }, 50, 6 );Thank You
- July 2, 2019 at 8:44 pm #70711
ing.acrd
ParticipantHello, thanks
But when i put this code on my functios.php
It told me there is an error on line ” $traking_added = false;”
it said syntaxix error unexpected ‘=’, expecting T_PAAMAYIM_NEKUDOTAYIM
- July 4, 2019 at 6:56 am #70969
Well, this code is more required. Please remove that and just add this line of code –
add_filter( 'wcfm_is_allow_change_main_order_status_on_all_item_shipped', '__return_true' );Please be sure you are using WCFM Ultimate 6.2.0+
