Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Toolset and wcfm default custom field question
- This topic has 4 replies, 2 voices, and was last updated 8 years, 2 months ago by
MOHO.
- August 5, 2018 at 9:57 am #27690
- August 6, 2018 at 6:17 am #27743
Yeah, Toolset shows warning for this. Is this blocks you from creating that field?
Between, how this slug already in use? Are you using any other third party plugin for the purpose?
- August 6, 2018 at 6:22 am #27745
MOHO
ParticipantIs this blocks you from creating that field?
-> Yes, i can’t add this field.2. Between, how this slug already in use? Are you using any other third party plugin for the purpose?
I use another plugin create this slug at product. - August 6, 2018 at 10:32 am #27762
MemberAhh … If you are already using a plugin for the purpose then why again creating same field using Toolset or WCfM Custom field?
Between, which plugin you are using here!
- August 6, 2018 at 10:45 pm #27804
MOHO
ParticipantI solve it!
I have use Toolset create it, so i can’t create again by Toolset.
Toolset team support me, thanks.
Please close it
- The topic ‘Toolset and wcfm default custom field question’ is closed to new replies.
