Best Multi Vendor Marketplace Plugin for WordPress › Forums › WC Marketplace › Top Seller Short Code Display Problem
- This topic has 4 replies, 2 voices, and was last updated 5 years, 4 months ago by
shaonmak.
- May 29, 2020 at 3:32 pm #136498
shaonmak
ParticipantHi there, i hope all of you are having a great day!
So, i have a problem with the Top Seller Short code, Which is that “How can i set columns to display in my page”. what i mean by that is for now my top seller is display as a 1 column format, how can i make it to display 2 columns instead of 1? - May 30, 2020 at 7:39 pm #136751
Sarmistha Chakraborty
Can you share us page URL where you are displaying “Top rated” seller, then we can guide you accordingly.
- June 1, 2020 at 7:06 am #137136
shaonmak
ParticipantGood day,
This is the page URL : https://marketplace.latitudeinnovation.com.my/Watch it on mobile version, on desktop version the column is in a 3 column 1 row format same with the featured products above, but in mobile version the format breaks, it no longer has the same number of columns and rows compared to the featured products section.
Thanks for the help!
- June 1, 2020 at 9:33 pm #137381
Try this css in your theme’s style.css –
@media only screen and (max-width: 599px) { /*************** ADD MOBILE ONLY CSS HERE ***************/ .wp-block-column { flex-basis: calc(50% - 10px)!important; flex-grow: 0 !important; }
- June 2, 2020 at 8:57 am #137548
shaonmak
ParticipantGood day!!
Just wanna update, it worked like a charm!!
Thanks for the help!!!
