Best Multi Vendor Marketplace Plugin for WordPress › Forums › WCFM – Ultimate › Translation order status updated
- This topic has 6 replies, 4 voices, and was last updated 5 years, 3 months ago by
Philip Baumgartner.
- September 5, 2019 at 1:18 pm #80180
- September 6, 2019 at 12:03 pm #80395
MemberWell, if you are checking “Notification” messages then you will not see translation for old messages, as those are from old log.
As you have added translation so your new notifications will be generated using translated text.
- April 17, 2020 at 2:32 pm #119985
Philip Baumgartner
ParticipantI have the same issue. The untranslated text is shown in the emails sent as “customer notes” and is also show in the order details where you can see all status updates (backend and frontend). all other texts are correctly translated, just this text does not work despite having translated the string in the “WCFM – WooCommerce Multivendor Marketplace ” language file (using LOCO).
Thank you for your helpAttachments:
You must be logged in to view attached files. - April 17, 2020 at 7:04 pm #120043
Sayan Naskar
Check for the string the in WCFM – Woocommerce Frontend manager and WooCommerce plugin as well and translate them. - April 18, 2020 at 1:07 pm #120269
Philip Baumgartner
ParticipantThank you for the reply.
The string is translated in the WCFM marketplace plugin (does not exist anywhere else) but still it’s not showing up in the email or oder details view in backend.
It seems that specific message comes from WCfM and not from WooCommerce. can there be a connection because I use the following code to set an order only to completed after all child-orders (From vendors) are completed. We have the “order sync” option disabled also.
add_filter( ‘wcfm_is_allow_mark_complete_main_order_on_all_child_order_complete’, ‘__return_true’ );Thanks for help.
Btw: if it was just for the website, I could use a plugin like “real time find and replace” but as it is also an issue for the email I need an overall working solution.Attachments:
You must be logged in to view attached files. - April 28, 2020 at 12:12 pm #124081
Philip Baumgartner
ParticipantHi, kindly following up on this issue.
I would need to translate that text as it is part of the order note that goes to customer when the whole order is finished.
Thank you. - April 28, 2020 at 12:19 pm #124085
Philip Baumgartner
ParticipantI realised that there is another string that I cannot translate. It’s the “Reverse withdraw” in the ledger book. Cannot find that string in all plugin files.
Looking forward to you help, thanks.Attachments:
